Bad Idea? Score And Snap For In A Corner. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-29-2011, 09:23 PM   #1
Rewards Points: 172
Bad Idea? Score and snap for in a corner.
I was wondering if I could score the backside of the board, snap it and instead of cutting the other side, use it as the corner? Instead of having to tape and mud. I'm pretty sure it's not a great idea, but was just wondering what would happen.
nateshirk is offline   Reply With Quote
Old 03-29-2011, 09:50 PM   #2
Old School
Willie T's Avatar
Shucks, give it a try, and let us know how it goes.
Willie T
Old 03-29-2011, 10:00 PM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Not a good idea.
There will be a 1/2" void behind the paper.
It's going to tear or rip if anything sharp goes into the corner.
A regular corner has the sheetrock and mud behind it to give it strength.
Don't do it.
Shame on you Willie...........
tcleve4911 is offline   Reply With Quote
Old 03-29-2011, 10:17 PM   #4
Rewards Points: 172
Originally Posted by tcleve4911 View Post
Not a good idea.
Don't do it.
That's what I was thinking. But what about puting mud in the void?
Again, I probably won't do it, but my curiosity is getting the best of me.
Old 03-30-2011, 11:55 AM   #5
dont do this you will be so sorry
first whats going to happen is you will have blisters form in your angles
second you just blew your r rating and expose your self to stucture damage in case of fire
the angel tape is used to give extra burn time and to cover the seam
this also stops airflow there are maney reasons to tape the angel and these are just a few
remember you half ass a job you get a half assed job
lrobertstoner is offline   Reply With Quote
Old 03-30-2011, 11:57 AM   #6
i also agree shame on ya willie that is bad advice
Old 03-30-2011, 01:07 PM   #7
Rewards Points: 172
Thank's guys. I'll do it right. I hate half assed.....
Old 03-30-2011, 02:33 PM   #8
Old School
Willie T's Avatar
Not a good idea.
Don't do it.
Willie T
Old 03-30-2011, 06:23 PM   #9
Drywall contractor
Rewards Points: 1,070
It'll work until the first time someone bumps/leans on the wall or when the lumber starts "moving" during heating/cooling season. The only time I have done this or would recommend it is on a bay window. The small distance between the windows is usually just over 3" on either side and there are 2 studs there. I glue the crap out of the studs on both sides, set the piece (scored on the back) in place, tack top and bottom with a nail, and let it alone until the glue sets. The header piece above and the pieces under the window get taped as usual.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Snap cutter wheel dull. Jim F Tools 3 09-16-2010 07:56 PM
Can you score and snap Travertine ryan5068 Flooring 4 07-18-2010 11:34 PM
