Backwards Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 10-23-2011, 07:28 PM   #1
backwards drywall
So i am remodeling a basement bedroom, installing an egress window, anyway the room has old accoustic glued on tile ceiling squares, they are glued to drywall. However the drywall on the ceiling is hung brown side down, I would really love to not replace it, can it be mud and taped? It is nailed up, so just flipping it will not work.
jgbuff is offline   Reply With Quote
Old 10-24-2011, 12:52 AM   #2
I've never seen it done. I wouldn't do it myself, and i'd never do it on a customer's house. I'd take it down, considering it is only one room.
If you are dead set on doing it, I would prime it first, tape it then texture it with a heavier texture. I have no idea if it would work for you or not.
chrisBC is offline   Reply With Quote
Old 10-24-2011, 09:13 AM   #3
Thanks for the input, I think I'll test some primer and texture on a test piece, if it works great, if not, i'll tear the old stuff down.
Old 10-24-2011, 09:52 AM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 570
Are you sure the face of the rock isn't just torn off.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-24-2011, 10:01 AM   #5
Rewards Points: 1,480
A skim coat might work.
mikegp is offline   Reply With Quote
Old 10-24-2011, 11:13 AM   #6
No, the ceiling tiles were glued on to the brown paper side, Its weird they wer'nt attached to furring strips like the rest of the basement ceiling. Its an old house though, built in 54. Not sure when they did the basement, but the ceiling tiles look 60's.
Old 10-24-2011, 02:10 PM   #7
That's a good idea
let us know how it works out,.
Old 10-24-2011, 05:42 PM   #8
Household Handyman
Rewards Points: 1,408
There are primers made particularly for sealing drywall. I would recommend two coats with good dry time in between. Have you considered a light textured ceiling, or are you wanting a good smooth finish?
Old 10-24-2011, 09:20 PM   #9
iminaquagmire's Avatar
Rewards Points: 338
Are you sure its backside out? Is it brown or yellowish brown? Reason I ask is that older drywall if left unsealed can yellow over time actually turning almost brown. Once that happens, I find the best action is a good high solids primer or a shellac based primer like Zinnser BIN primer. Though even if it is hung backwards, some good primer and paint will still fix it up.
iminaquagmire is offline   Reply With Quote
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
