-   -   BackerBoard not flush with drywall at seam. Request Solutions (http://www.diychatroom.com/f101/backerboard-not-flush-drywall-seam-request-solutions-53880/)
Mitch3GP 09-26-2009 08:56 PM
All,
Thanks for the forum.
I've placed Durock on the shower surround. The framing is a bit off so where the cement board meets the drywall, the cement board is not flush. Rather its raised about 1/8 to a 1/4". This is only about three out of five feet. It is flush in the corners.
A couple options are
to use mud to smooth it out.
Use a belt sander to grind down the high spots of cement board.:eek:
Or cut three more inches of drywall off to the next framing stud, reconfigure the cement board and secured to the stud and make the seam flush.
Thanks for your feedback
Ineedhelp2009 09-26-2009 10:46 PM
Originally Posted by Mitch3GP (Post 332986)
All,
TTT
I like option 1
hopefully someone else will chime in
LeviDIY 09-27-2009 09:43 AM
I'm assuming you are tiling over the cement board... could you find a rounded end cap that handles that distance? I had the reverse issue (CBU an 1/8th thinner than the drywall), and in my case the tile with thinset almost made up the difference.
Bud Cline 09-28-2009 01:59 PM
Grind it down and move on.:)
