Attaching Drywall To Bottom Of Stairs - Drywall & Plaster - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-22-2012, 03:01 PM   #31
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
So, in essence what they've done on my stairs would be similar to that of a boxed staircase, in that the entire 2x12 retains its rigidity. Just instead of routing out areas for the treads and risers, the attached a piece of external wood to do that?
hyunelan2 is offline   Reply With Quote
Old 02-22-2012, 03:02 PM   #32
Originally Posted by Willie T View Post
Yeah. Did you know that the sheet metal on early automobiles was "welded" together by hammering on the joints till they fused together? No one would do that today, no matter how cool it is.
Or pay for it.
M Engineer is offline   Reply With Quote
Old 02-22-2012, 03:12 PM   #33
Old School
Willie T's Avatar
Yeah, sounds like it. And it's legal, as far as I understand it.
Willie T
Old 02-22-2012, 03:36 PM   #34
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
Before I read this post I finally got it, that is exactly what they did. Instead of mortising in the 2X12 they cut stringers out of 1X12 and nailed to the 2X12, same difference as mortising just cheating and not as time consuming or craftsman like.
I have built several of the stairs with mortised in treads and risers but not this way. The down side of doing it this way would be not being able to use the wedges that are used in a full mortise to keep the squeaks out. The riser will hold the tread rigid all the way across and with the 2X12 stringers as you have it will be stronger, like Willie said, as you have the full 2X12.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 02-22-2012, 05:11 PM   #35
drywalling stairs
I am a framer from Canada. Your stairs are built fine. A 2"x4" down the middle of the stair parallel to your stringers would give plenty of strength as backing for the drywall or 2"x4"s on flat perpindicular to the stringers and toenailed to the stringers.
kjk11 is offline   Reply With Quote
Old 02-22-2012, 10:04 PM   #36
hyunelan2's Avatar
Rewards Points: 692
Originally Posted by jiju1943 View Post
I have built several of the stairs with mortised in treads and risers but not this way. The down side of doing it this way would be not being able to use the wedges that are used in a full mortise to keep the squeaks out. .
I'm guessing that's where the construction adhesive comes in? Probably not as permanent as a mechanical wedge, but probably not likely to let go in the next few decades.
Old 02-22-2012, 11:04 PM   #37
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
If your construction adhesive is as strong as the one I used you would have to tear the treads up in pieces, it was just that strong.
Jim
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 04:04 PM
Attaching deck stairs to brick patio skipaola Building & Construction 2 10-19-2010 01:55 PM
Attaching bottom plate to concrete at edge near wall BlueBSH Building & Construction 13 06-13-2010 04:05 PM
Anything special for attaching drywall to the ceiling? tripower Drywall & Plaster 4 06-29-2009 08:29 AM
drywall on stairs goodman Carpentry 11 03-20-2005 10:45 AM
