Attaching Corner Bead - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-23-2014, 12:48 AM   #1
Rewards Points: 422
Attaching corner bead
We just drywalled the ceiling in my daughter's basement, and on the bottom edge of the soffit, there is about an 18" span(at the end of an inside corner) where the corner bead cannot be screwed in. There is no wood to attach it to because there is a HVAC duct there. Any advice? Will it be OK, or should I use adhesive under the bead there? Thanks.
Jim McC is offline   Reply With Quote
Old 01-23-2014, 04:37 AM   #2
Rewards Points: 14,312
Not a great plan to have unsupported drywall, far more likely to crack.
If I had to do it I would use this.
http://www.homedepot.com/p/Strait-Fl...t-90/202579261
If not that then the metal backed paper tape made by the same company.
Old 01-23-2014, 12:41 PM   #3
Rewards Points: 422
Thanks Joe. Why would that be better than the metal backed paper tape? And both of those can be used on outside corners?
What do you guys think about using the spray adhesive, staples, and vinyl corner bead?
Old 01-23-2014, 05:57 PM   #4
Rewards Points: 6,034
I have used all the above and must say I like them all. I think for this app. I would prefer the vinyl bead using spray adhesive and stables only because I think it would be a little more ridgid. You really should have framed around the duct with 1x just to have something to attach too.
Old 01-23-2014, 06:15 PM   #5
Rewards Points: 422
Thanks. I did frame around the duct, just not under it(about 18"). If I use vinyl bead on this soffit, I should use it for the other soffit too, correct? Because the 2 soffits meet at an inside corner.
Old 01-23-2014, 08:01 PM   #6
I don't guess it would really matter but I would. I mean your going to have the stables, glue, why not use them.
Old 01-23-2014, 11:48 PM   #7
Rewards Points: 422
Thanks. The vinyl bead seems so flimsy. How do I keep it in a straight line as I attach it?
Old 01-24-2014, 06:47 AM   #8
Mark a straight line with a pencil.
Old 01-24-2014, 06:48 AM   #9
Double posted.
Old 01-24-2014, 07:01 AM   #10
Joe's correct use a level to get it straight then mark with a pencil. Then glue and stable it to the line.
Metal corner bead vs Paper-Faced bead CMHbob Drywall & Plaster 6 04-09-2017 07:39 PM
Corner bead options Dorado Drywall & Plaster 6 06-01-2013 02:22 PM
holding paper faced corner bead in place with tape Dorado Drywall & Plaster 7 05-20-2013 05:49 PM
Replacing corner bead and patching handinovice Drywall & Plaster 7 05-05-2013 05:18 PM
Corner Bead for Double Drywall? whipper Drywall & Plaster 11 08-12-2009 01:19 PM
