Attach Drywall At The Wall Bottom - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-15-2011, 07:42 PM   #1
Attach drywall at the wall bottom
I am changing out plywood paneling and putting in drywall. The house has a wood subfloor and the sole plate is ressesed into the floor. Less than a 1/2 inch is exposed. Will I need to add cuts of 2x4 between studs to skrew the drywall at the base of the wall. Thanks
Also the door jambs fit 1/4 inch wall. The sheetrock is 1/2. What can I use to fill the gap under the trim? Will caulk work or will I need a 1/4 in wood shim.
Restyle is offline   Reply With Quote
Old 12-15-2011, 07:44 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Uhh..Not really required. But it wouldn't hurt. How many blocks are we talking about?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 12-15-2011, 07:48 PM   #3
22Feet of hall both sides if its not necessary I will leave it out. I'm using 5in base molding. maybe that will help.
Old 12-15-2011, 07:53 PM   #4
Disabled wood vet
titanoman's Avatar
The drywall could end up slightly wavy, but when you caulk the baseboard to the wall that should prevent that.
And as long as nobody goes around kicking the walls..
Old 12-15-2011, 07:56 PM   #5
Rewards Points: 13,274
Not a big deal if it's not attached at the bottom, in fact the drywall is suppost to be about a 1/2 off the floor anyway so in you case it not going to hit anything. It needs to be up off the subfloor because floors are never level or perfectly flat, if it sat flat on the floor the sheetrock would not be level.
Old 12-15-2011, 07:57 PM   #6
Disabled wood vet
titanoman's Avatar
<img src="http://www.diychatroom.com/attachment.php?attachmentid=42605"/>
Also the door jambs fit 1/4 inch wall. The sheetrock is 1/2. What can I use to fill the gap under the trim? Will caulk work or will I need a 1/4 in wood shim.[/QUOTE]
That's too much caulk. It would be nice to get wood behind it.
Old 12-15-2011, 08:06 PM   #7
Rewards Points: 52
Wouldn't necessarily have to be 2x, but I might be inclined to toss down just some 1x2, or whatever is cheapest, not so much as a nailer, but just to eliminate any possibility of waves that titanoman mentioned once the basboard goes down.
Old 12-15-2011, 10:03 PM   #8
sparks1032's Avatar
I am with everyone else not necessary but if anticipated hard use it might not hurt
sparks1032 is offline   Reply With Quote
Old 12-15-2011, 11:25 PM   #9
thanks
Bottom Plate for Non-Load Bearing Wall cobrakai Carpentry 2 02-08-2011 12:56 PM
Wall construction for insulation support WillK Building & Construction 3 12-09-2010 02:55 PM
How to drywall wall with HVAC trunk and pipe penetrations daphilli Drywall & Plaster 3 09-27-2010 03:15 AM
Removing built in drywall shelves to wall mount TV homerb Project Showcase 0 05-19-2010 01:34 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
