Asbestos In Metal Lath/plaster Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-24-2013, 03:55 PM   #1
Rewards Points: 91
asbestos in metal lath/plaster ceiling?
My house was built in 1948. A room in the basement has a metal lath and plaster ceiling, which either was original to the house, or was put up when the room was remodeled in the early 70s. I sent a sample of the plaster that actually sits on the metal lathe to get asbestos tested, and it came back with no asbestos detected.
But now that I look at other parts of the ceiling, there are areas that have another couple of outer layers above this lower layer of plaster. I didn't notice this before, otherwise I would have sent all layers to be tested. Should I bother testing these outer layers as well? These layers don't look to be decorative in any way; they are thin, almost like layers of skimcoat.
debiasio is offline   Reply With Quote
Old 09-24-2013, 06:12 PM   #2
Rewards Points: 6,652
If the test came back no Asbestos, I would not go any further. Just wear long sleeve shirts, long pants, gloves, masks, eye protection, when taking down the material. Plaster dust will go everywhere, and will also irritate the throat & sinuses, if you do not wear some sort of mask.
After you get done in that room, vacuum off your clothes, shake them outside before going inside. Always wash your hands and wipe your face off, not washing it, to get off any dirt, before eating.
Reason for the above, is that older homes are more apt to contain Lead paint on the walls, than Asbestos. Another item, is do not run the hvac system if you can get by not having to, and use a fan to pull the air out of the room, to move the dust outdoors, so you can lessen having the dust migrate all throughout the rest of the house, even though you have plastic segmenting off that area you are working in.
Old 09-24-2013, 06:19 PM   #3
Rewards Points: 512
i mask up and everything like gregzoll said but i spray the plaster with water and continue to spray it down while your taking it down. also spray the plaster piles and dust on the floor to try and keep the dust down. i'd also look into renting an air scrubber to collect the dirt in the air.
princelake is offline   Reply With Quote
Old 09-24-2013, 07:09 PM   #4
Rewards Points: 91
Thanks. I didn't think about spraying the ceiling and piles. That's a good idea. I've been wearing a P100 mask with glasses, longsleeves and pants. Seems to be working mostly OK.
Old 09-24-2013, 07:31 PM   #5
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 918
Did they test the paint for lead?
Anything that was painted before 1978 should be.
http://www2.epa.gov/lead#
Sir MixAlot is offline   Reply With Quote
Old 09-25-2013, 06:18 AM   #6
Rewards Points: 91
They didn't test for lead, but it doesn't look like the ceiling is painted, either.
Old 09-27-2013, 11:32 PM   #7
Rewards Points: 610
If you mix a little vinegar in the water it breaks the surface tension of the water and helps it penetrate the materials you are removing
techpappy is offline   Reply With Quote
Old 09-27-2013, 11:42 PM   #8
A little bit of dish soap will also work.
Old 09-28-2013, 02:32 AM   #9
Rewards Points: 626
Dish soap works the best. Fire departments use dish soap like dawn to break down the water tenion so the water soaks in better.
Nailbags is offline   Reply With Quote
Old 09-28-2013, 06:11 AM   #10
Rewards Points: 5,992
Fabric softener will work better than dish soap.
ToolSeeker is online now   Reply With Quote
The Following User Says Thank You to ToolSeeker For This Useful Post:
Nailbags (09-28-2013)
Old 09-28-2013, 01:18 PM   #11
Vegans will not touch it, due to Fabric Softener is made out of rendered animal fats.
Old 09-28-2013, 01:43 PM   #12
Rewards Points: 626
Good to know
metal ceiling nelsey Painting 8 12-06-2012 12:22 AM
Mounting ceiling fan with old metal brace, need joist?? nimchimpski20 General DIY Discussions 3 11-09-2010 06:18 PM
Using metal studs with a suspending ceiling MinerReb Remodeling 7 04-02-2010 05:57 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
