Anyone Know What This Is - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Like Tree3Likes
Old 10-10-2016, 08:58 PM   #1
Rewards Points: 174
Anyone know what this is
I pulled my bathroom vanity in my 1946 home to find this peach colored stuff in the wall. I think they used it to patch up where they cut into the wall. However it is falling apart in areas and I plan to mud the room. I'm thinking I might need to remove it before I proceed. The original walls should be plaster. The white above is where I primed the walls after pulling wallpaper. Thanks.
jwiens is online now   Reply With Quote
Old 10-10-2016, 09:28 PM   #2
Gymschu's Avatar
Rewards Points: 822
Re: Anyone know what this is
Could be some patching material from the 40's or adhesive used to help attach the vanity to the wall.
Giving us your general location helps us better help you!
Old 10-10-2016, 09:30 PM   #3
Rewards Points: 256
Looks like Bondo lol
Sir MixAlot likes this.
BayouRunner is offline   Reply With Quote
Old 10-10-2016, 09:37 PM   #4
Rewards Points: 174
Well the vanity didn't seem attached to it. I figure all I can do to fix the horrible walls in here is do a very heavy wall troweled texture like the Santa fe. Perhaps i should just go ahead and go over all of this... if I wasn't in the middle of a kitchen remodel is put up new drywall.
Old 10-11-2016, 12:17 AM   #5
Rewards Points: 13,694
No way should you be using any form of texture in a bathroom or kitchen or bathroom for a whole list of reasons.
Old 10-11-2016, 01:07 AM   #6
Rewards Points: 174
So what should I do? My family is having a very hard time with all of the demolition. I have to do something quick and easy and fairly inexpensive. All of our money is in the kitchen remodel. The bathroom walls look incredibly uneven after the wallpaper was removed from the walls and ceiling. I seriously doubt my ability to do a smooth texture over these walls...
Old 10-11-2016, 06:44 AM   #7
Rewards Points: 14
If it is bondo (2 part epoxy used to fill holes), you should be able to sand it smooth with a random orbit sander. Once smooth a coat or 2 of setting type joint compound sanded and painted should get you back in business. I use setting type because i can put 2 or even 3 coats on in a day using 20 minute quickset.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 10-11-2016, 07:04 AM   #8
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 908
You could first do a coat of mud over the that bad area behind the vanity.
Then give the old skim coating with the paint roller trick a go...
Here's a video I put together:
Part 2 Doing the second round of skim coating:
Sir MixAlot is online now   Reply With Quote
Old 10-11-2016, 07:58 AM   #9
Rewards Points: 3,831
I sure as heck would not sand it unless I knew exactly what it was.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 10-11-2016, 08:59 AM   #10
Rewards Points: 174
Thanks everyone. J had watches your videos on the skim coating Sir Mixalot. I just wasn't sure it would work on a wall with so much damage. I have large areas that are like hills and then areas that are sunken. nothing uniform like a texture to smooth over. I'll give the roller method a go though. Thanks.
Old 10-11-2016, 09:00 AM   #11
Rewards Points: 174
Quick question. In the video it looked like you were using 14" scraper vs a trowel. Can you tell me what I should get?
Old 10-11-2016, 09:05 AM   #12
Rewards Points: 174
Or was it a taping knife? I have a 10" taping knife. Is that big enough?
Old 10-11-2016, 10:25 AM   #13
Rewards Points: 908
Yes I'm using a 14"drywall taping knife in the video. A 10" taping knife will work if that's what you have or what you're most comfortable with. But I a like using a bigger knife for skim coating.
Old 10-11-2016, 06:08 PM   #14
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,596
You letting the hair grow out man?
Did you catch much of Mathew?
Old 10-12-2016, 01:20 PM   #15
Rewards Points: 908
Haha. No that's my helper rolling on the joint compound and I'm the tall goofy one smoothing out the skim coat.
As far as hurricane Matthew?
The storm was predicted to give us a direct hit. Which would have been catastrophic. Luckily it stayed 20 miles off of our coast which saved us. I feel very lucky to have dodged that bullet!
Only damage is trees and fences down. AC unit destroyed.
Here's a couple pics from one of my places.
I've got some video of the damage in my area that I'm going to be posting on my Youtube channel as soon as I get past all the storm cleanup and all services are restored. https://www.youtube.com/c/paulpeck
