Any Tricks To Get Into A Small Space? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-24-2014, 12:52 PM   #1
Rewards Points: 117
any tricks to get into a small space?
here is a pic of a wall im redoing.
drywall meets plaster wall.
its uneven by 1/4 inch so i have to fill it in to make it even.
the space i have to get into is about 1 1/2". i cant seem to find a putty knife small enough to fit to smooth out the mud evenly.
does anyone have any tricks i can try or suggestions?
http://img.photobucket.com/albums/v2...psycpxvcxp.jpg
echobravo is offline   Reply With Quote
Old 04-24-2014, 06:31 PM   #2
Rewards Points: 12,856
Got a real mess there. Sure looks like someone did not know your suppose to add shims before the drywall is installed so it comes out even with the wall.
Going to have to use hot mud to fill in the gap across that whole area, not just there the step is.
Going to need a whole lot wider knife then 1-1/2 to get that one right.
Old 04-25-2014, 11:03 AM   #3
Rewards Points: 117
the drywall is raised higher than the plaster due to the lathe.
cant use any wider knife than 1 in thats all the space i have to work with..
thanks for the reply
Old 04-25-2014, 11:53 AM   #4
Rob
Robpo's Avatar
Rewards Points: 826
I think you are too close to see what is really there. maybe a pic from farther away.
Robpo is offline   Reply With Quote
Old 04-25-2014, 03:09 PM   #5
Rewards Points: 744
Yes, a picture from further out, please. It's hard to tell what we're looking at, in that first pic.
Seattle2k is offline   Reply With Quote
Help neede to work out how to get into this small space. pastcaring Carpentry 0 12-04-2012 11:42 AM
Open crawl space to heated basement benjamincall HVAC 1 03-04-2011 08:52 PM
Ideas for landscaping small space mscottonblossom Landscaping & Lawn Care 0 02-28-2011 06:43 PM
Crawl Space Advice mjarema414 Building & Construction 0 02-04-2011 09:09 AM
Can I run a small (500 watt) 240 V space heater at 120V? pcampbell Electrical 6 01-08-2009 10:56 PM
