#1 |
Any tips on mudding/touching up this tight spot
Tight spot between soffit and stairs.
Flex 1" knife is not happening. Maybe if I tape a pipe to the handle to get better reach- but I need to mud/pull it tight as even getting fingers in there is a chore. Any tips or suggestions
#2 |
Can you glue some molding in there? Or even extend the ceiling all the way to the stairs? Does that area have a reason to be higher than the ceiling?
#3 |
The shot you see is just the tight spot on the angle/incline of where the stair meets the soffit. The high spot is the ceiling. It's just the way the pic was taken.
Molding would not be a good thing in that spot. I suppose you can only really see it if you pointed a light and looked for it....when paint is on it, it can only blend in more. |
| Display Modes | |
| Grouting in tight spaces...tips needed | Ironlight | Tiling, ceramics, marble | 7 | 01-13-2012 04:22 PM |
| PVC main shut off too tight | lmbgm | Plumbing | 3 | 10-23-2011 03:01 PM |
| Toilet Ventilation & Kitchen Tips | johnelliot | Kitchen & Bath Remodeling | 1 | 03-29-2011 11:34 AM |
| Tips for HEAVY sink install | Sarah24 | Plumbing | 3 | 12-04-2008 08:01 PM |
| Breaker for Spot light and outlet receptical | hgiljr | Electrical | 4 | 08-16-2007 02:10 PM |
