Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 01-08-2013, 09:53 AM   #1
Any *Pro Hangers* in the house
I have 2 bags of durabond brown bag unopened from my last project about 5-7 months back. They have been sitting in my climate controlled room since then....
Would you say OKAY to use or junk it.
I'm not sure what the exp. date is on these sorta things - can't presume if it dries hard and doesn't crack, it's *okay* for paint, or will it micro crack, etc down the road ?
mobiledynamics is offline   Reply With Quote
Old 01-08-2013, 10:07 AM   #2
If it's been kept dry it should be fine.
Old 01-08-2013, 05:10 PM   #3
I would not hesitate to use it.
Old 01-08-2013, 05:48 PM   #4
paper hanger and painter
chrisn's Avatar
It will be fine
Old 01-08-2013, 09:28 PM   #5
Got it. I was not sure if I was going to treat the hot mud like thinset.
With thinset, once I'm done with a project, It's trash.
Even if I'm doing back to back projects, if the bag was opened and sitting around for 2 months, I'm trashing it.
The air, etc will just have the thinset fail - which is far worse, cause you have finished tile, etc and it's the substrate that has failed.
My house's previous owner - DIY horror stories Leah Frances General Discussion 118 03-14-2013 02:27 AM
Attaching wood fence to house TheCowGod Building & Construction 5 04-13-2012 04:57 PM
Attach ledger to vinyl sided house JamyTheBuilder Building & Construction 3 03-14-2012 03:54 PM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Moving a House 70 miles- Practical? GOTHICrevivalRULES Building & Construction 19 11-27-2008 09:58 PM
