Any Chance Of Saving This Seam? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-26-2013, 08:10 AM   #1
Jack of all - master none
hyunelan2's Avatar
Rewards Points: 692
Any chance of saving this seam?
Any chance of salvaging this seam, or should I cut the whole darn thing out and start over? [It's a tape seam on drywall, built circa 2002].
Haven't ever had a seam let go quite this bad. It's been about like this since we moved in, but has gradually gotten worse. Now that my home improvement hiatus is about over, I'm starting my plans to attack some things. The bedroom is getting a complete gut and rebuild: built-ins, moving TV cabling to opposing wall, repaint, building a platform bed and (eventually) all new furniture. First step is fixing this ceiling though. It is at the peak of the vaulted ceiling, conveniently about 12' high.
hyunelan2 is offline   Reply With Quote
Old 12-26-2013, 09:08 AM   #2
Rewards Points: 626
looks like you need to redo the joint, I would use Trim tex, Magic corner bead for that problem. hope that helps.
Nailbags is offline   Reply With Quote
The Following User Says Thank You to Nailbags For This Useful Post:
oh'mike (01-04-2014)
Old 12-26-2013, 10:54 AM   #3
Rewards Points: 153
Cut it out and redo it. If the board wasn't floated on that edge when it was installed, it may crack again.
eandjsdad is offline   Reply With Quote
Old 12-26-2013, 01:49 PM   #4
Rewards Points: 66
Have you checked your foundation?
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is online now   Reply With Quote
Old 12-26-2013, 02:10 PM   #5
Rewards Points: 13,712
I agree, all the old tape needs to go.
My biggest fear is with your snow loads may be causing the issue with undersized rafters, improper collar tie nailing pattern, ECT.
I use this for those type angles.
http://www.homedepot.com/s/drywall%2520tape?NCNI-5
Old 12-26-2013, 02:42 PM   #6
hyunelan2's Avatar
Rewards Points: 692
No issues anywhere else, and this is a 2nd story bedroom, so I'm thinking foundation issue is unlikely.
Thanks for the help guys. I figured I'd be cutting it out, but didn't want to do it and then have someone down the road say, "you didn't need to cut it all out, all you needed to do was _______ ." After our New Year's guests have left, my wife and I will be moving into the guest bedroom so I can make a mess in here getting it fixed.
Old 12-26-2013, 02:51 PM   #7
Rewards Points: 626
That is a cheap knock off of Magic Corner bead. all he should need to do is to redo the joint with it mud and sand repaint.
Old 12-26-2013, 05:09 PM   #8
Rewards Points: 512
http://www.no-coat.com/.docs/pg/10243
no coat is the best product for this type of ceiling. i would cut out the other side and redo it while your up there and painting.
princelake is offline   Reply With Quote
Old 12-26-2013, 08:06 PM   #9
Rewards Points: 5,974
This is a very common problem with cathedral ceilings. I agree with the no-coat. But with a seam that big I might bed it in hot mud.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
oh'mike (01-04-2014), princelake (12-28-2013)
Old 12-28-2013, 06:27 PM   #10
Rewards Points: 512
i'd use the green lid mud for setting the no coat and going over it with hot mud on your first coat then then a final skim or 2 with a finish mud.
The Following User Says Thank You to princelake For This Useful Post:
Old 01-04-2014, 05:52 PM   #11
Rewards Points: 744
Green lid on the east coast may not mean the same thing on the west coast.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
Nailbags (01-04-2014)
Old 01-04-2014, 06:43 PM   #12
Rewards Points: 626
I have always used Beadx taping mud better then the green lid stuff plus I have not used USG all purpose mud in years. hardly ever see it at the drywall supply house.
Old 01-04-2014, 07:12 PM   #13
JOATMON
ddawg16's Avatar
Rewards Points: 1,820
No kidding....I went to my local building supply and they said "What?"
Here you can get dry bags of 30 min, 40 min and 90 min mud along with Red Dot.
I just did one room of my addition using the 40 min mixture. Much better to use than the regular premix stuff for the initial mudding. It's usually dry in 2 hours ready for sanding.
Old 01-05-2014, 02:55 PM   #14
Yes we get in habits that may not mean the same thing to others. In fact USG makes 2 green lid muds, all purpose with a bright green lid, ultra light in the puke green lid. From now on I will say all purpose, or bright green.
Old 01-05-2014, 03:43 PM   #15
JOATMON
ddawg16's Avatar
My 40 min came in a white paper bag with black lettering.
Basement Leak where Concrete Blocks seam with Poured Concrete stankholio General DIY Discussions 4 11-01-2013 07:59 PM
lip created by previous seam rufuscobb Drywall & Plaster 4 10-16-2013 05:17 AM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 02:58 PM
Visible seam on fixed hole in ceiling? kcrossley2 Drywall & Plaster 24 06-18-2010 07:58 AM
Carpet Seam help Goldglv Flooring 6 02-01-2010 07:30 AM
