Another Method Of Hanging Ceiling Drywall? - Drywall & Plaster - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-09-2009, 05:55 PM   #16
Drywall contractor
Rewards Points: 1,070
Originally Posted by Scuba_Dave View Post
My cathedral celiling is 12' up
I'll rent a lift
Or possibly hire it out & the mudding
Hiring it out might be the best bet as you'll need some sort of scaffold for the finishing (unless you just want to deal with a ladder). If you don't have one, you'll have to rent that too. A contractor should be able to do the job reasonably by the time you consider rental fees, and get it done more efficiently (quicker). Though you won't have the "fun" of doing it yourself....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 08-10-2009, 10:15 AM   #17
How well do those cheap ebay lifts work?
VelvetFoot is offline   Reply With Quote
Old 08-10-2009, 10:36 AM   #18
Wounded Mathematician
shtoink's Avatar
Since this thread has been dredged up and I am the original poster, I might as well give an update.
I ended up buying a used dw lift that was for sale on Craigslist. The guy selling it was in a similar situation - it was more cost-effective for him to buy one than rent, but he only needed it to drywall one job. He gave me a good deal on it. I used it for the 4 or 5 days it took to hang all my drywall and then I listed it on Craigslist. I ended up selling it for the same price I bought it.
The guy I sold it to only needs it for one job and then he plans to resell it.
I hung all of my drywall solo. Some of it was 10' sheets. It was sometimes cumbersome to maneuver into the tricky spots in my kitchen above the counters but totally doable solo when planned properly.
The poets have been mysteriously silent on the subject of cheese.
G.K. Chesterton
shtoink is offline   Reply With Quote
Old 08-10-2009, 10:40 AM   #19
Drywall contractor
Again, I can't speak from actual experience, but I would think they'd work fine for occasional use. I wouldn't expect them to stand up to daily use very well. Harbor freight sells a lift that I would assume to be about the quality to be expected from EBAY lifts. From the LOOKS of it, it should work fine, but I don't buy HF tools for long term use. I consider them "disposable" or limited use......
Old 08-10-2009, 10:42 AM   #20
Drywall contractor
Shtoink, you beat me to the post. Glad it worked out!
Old 08-10-2009, 10:48 AM   #21
I'll probably do something similar, thanks.
Old 08-10-2009, 10:57 AM   #22
RippySkippy's Avatar
I have a DW lift from Menards...and aside from the color, it's 99.9% identical to the PanelLift model. I love mine...I use it to support all sorts of overhead lifting tasks...sometimes it does get a bit cumbersome with the tricycle wheel set up..but it's better than bust'n a gut!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 09-21-2012, 09:50 AM   #23
Rewards Points: 6,034
I would never use the one in the picture it be a continuous balance act that you would not enjoy. If you can get a helper you should be able to hang 4x8 1/2" sheets pretty easy. or with the aid of a helper make a deadman out of scrap 2x4s. And in case you are not aware of it they now carry a light weight 1/2"4x8 sheet, I would ask about it.
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Hanging drywall basement ceiling from engineered wood I-beam joists ja_trusty Building & Construction 6 10-09-2008 11:06 AM
Hanging Ceiling Drywall AFTER Wall Drywall? mfleming Drywall & Plaster 10 10-06-2008 03:32 PM
my corners are cracking when hanging drywall in the ceiling, why? yummy mummy Building & Construction 16 12-22-2007 12:09 PM
Hanging Drywall over ceiling tiles bjorgens Remodeling 4 12-19-2007 12:59 PM
