Anchoring To Sheetrock With Concrete Behind It - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 03-26-2011, 10:39 PM   #1
Anchoring to sheetrock with concrete behind it
My walls have matal studs 18" on center. Anhoring anything heavy to them has been a chore. I've used toggle bolts in the past but I've only got about a half inch of hollow space behind the sheetrock, then the exterior concrete wall. There are no studs nearby.
What can I use to anchor something to the wall with a maximum shear rating of about 75-100 lb per anchor?
saik0 is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
how to fill the gaps between concrete blocks? micapavlov Building & Construction 4 01-03-2010 04:53 PM
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 04:26 PM
anchoring sole plates to concrete floor be_leafer Building & Construction 9 02-05-2009 08:18 PM
Garage concrete and driveway asphalt repairs creamaster Building & Construction 4 07-12-2008 10:51 PM
