Anchoring The Frame. - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 08:34 PM   #1
Anchoring the frame.
Hey guys. I'm new here. I'm lookin for a little advice. I'm about to try to fix up my bedroom in the basement because I'm tired of having no walls lol. I know most of the basics of building a frame and hanging drywall but I never really liked the idea of nailing or drilling wood to concrete. I mean I'm no pro so I really don't know. But is there a better alternative to anchoring the frame or is my best bet just drilling it straight into the concrete.
Darthbudz is offline   Reply With Quote
Old 02-24-2012, 08:40 PM   #2
Rewards Points: 12,882
There's only about two ways, use Tap Cons, or powder shots with nails. SOmethings got to keep the wall from moving side to side.
Old 02-24-2012, 09:12 PM   #3
i had considered the tap cons. what are the powder shots with nails? i'm not really sure what you mean.
Old 02-24-2012, 09:50 PM   #4
http://www.ramset.com/fasteners_powder.asp
Old 02-24-2012, 09:53 PM   #5
DIY staff
Rewards Points: 7,174
The 22. calber guns Joe speaks of are cheap--$25--or less--and the pins and shots are also reasonable.
Best--fastest and cheapest way to anchor to concrete.
Darthbudz (02-26-2012)
Old 02-24-2012, 09:56 PM   #6
retired union carpenter
Send a message via Yahoo to coupe
Originally Posted by Darthbudz View Post
i had considered the tap cons. what are the powder shots with nails? I'm not really sure what you mean.
go to your local hardware store, ACE, or whatever? and rent a ram set powder gun for a day. buy some 2 1/2 inch ram set nails, you may need to start nails in bottom plate, if too long for the gun? they can tell you the shot power you'll need to shoot into concrete. I'd say brown #2 shots. shoot twice if needed?
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 02-26-2012, 12:58 AM   #7
Thanks for the replys guys.
I'm off tomorrow so I'm gonna look into getting one of these guns. I'm gonna check in with sears and see what I can find.
Old 02-26-2012, 08:52 AM   #8
DIY staff
Thanks for the update---2 1/2" pins---yellow loads----
Old 02-26-2012, 01:57 PM   #9
Registered User
Rewards Points: 4,936
Use a sill sealer under the p.t. bottom plate: http://www.greenbuildingadvisor.com/...-building-code
Take your best shot: http://www.buildingscience.com/docum...study-analysis
Be safe: http://docs.google.com/viewer?a=v&q=...33otStRi7Aff7g
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 02-26-2012, 05:25 PM   #10
Originally Posted by GBR in WA View Post
I'll definitely be using those links.
The Following User Says Thank You to Darthbudz For This Useful Post:
Gary in WA (02-27-2012)
storm door frame vcerilli Carpentry 1 11-05-2011 03:35 PM
narrow frame dual pane windows tns1 Building & Construction 0 12-21-2010 03:05 PM
exterior door frame size and rough opening kevincw01 Building & Construction 3 06-06-2010 09:26 AM
Exterior wood door frame on concrete floor RosenKen Building & Construction 3 06-05-2009 03:23 PM
Replacing aluminum frame windows gallasm Remodeling 2 01-05-2009 11:03 AM
