Am I Asking Too Much To Get Knock Down To Match - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 12-13-2010, 10:34 PM   #1
Rewards Points: 337
Am I asking too much to get Knock down to match
So I am finishing up the walls for a remodel. We decide on medium knock down. They start spraying at 4 pm its getting dark I question them no problem. Well the texture was much lighter than the test board and the guy helper missed a 1x3 foot section of wall, did not knock it down Then helper is cleaning up and gouges one of the walls with the knife in his pocket. Next day when it's light, we inspect and the trainee that did the knock down left several blade marks, not small very noticeable in several walls and they missed a 3"x 5" corner of the ceiling.
So, next day they sand down two walls skim coat again and owner reshoots with his hopper and does the KD. Looks great just like the test board but now it does not match the ceiling or a couple other walls. The corner of the ceiling he applied some mud "little blobs" by hand and knocked them down but they appear to uniform is size. He said he can sand the corner again and just hit it with the hopper "small area and knock it down.
So I am asking too much that it's uniform?
thanks!
titan7 is offline   Reply With Quote
Old 12-15-2010, 10:37 AM   #2
Drywall contractor
Rewards Points: 1,070
No, you're not asking too much. The contractor should take responsibility to get it the way it's supposed to be even if he has to re-sand the entire area and re-do it. That's why you don't have a "trainee" doing the work unsupervised......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Quarter Round for hardwoods - White or match the floor? mr_ekco Flooring 6 02-22-2011 06:00 PM
How to frame new floor to match existing floor height taylor01 Carpentry 4 04-04-2010 08:59 PM
Painting New Roof Shingles to match old ones? Lgarced Painting 0 03-25-2010 08:46 PM
Concrete Does not Match ivanl Building & Construction 15 08-24-2009 01:35 PM
Knock down application tips needed gmhut Painting 1 07-31-2008 09:30 PM
