Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 04-21-2010, 10:34 PM   #1
Question
Almost fell through ceiling repair
I was in the attic and fell between the ceiling joist. Now I have a crack in the ceiling in my daughter's bedroom. The crack is about 10 inches long. It does look like the crack is through the paper on the drywall. Can I fix this just by sanding, mudding and repainting, or should i tape the crack first?
Thanks for the info.
Brad B
Bradley B is offline   Reply With Quote
Old 04-21-2010, 10:48 PM   #2
Super Moderator
Go back into the attic first--Return to the seen of the crime---and lay a piece of plywood over the damaged drywall,
Now--go to your daughters room and add some drywall screws to the damaged drywall.
Now you're ready to mud.
If any paper actually tore or is bulged--knife out the bad paper and use paper tape or mesh.
Mud in the usual way.Blue bucket and a wide blade--very thin coats.---Mike--
Bradley B (04-21-2010)
Old 04-22-2010, 08:48 AM   #3
Sorry for my denseness, but what does 'blue bucket' refer to? A brand?
I've got a ceiling repair of my own in the wings.
Thanks.
VelvetFoot is offline   Reply With Quote
Old 04-22-2010, 09:35 AM   #4
Drywall contractor
If you use mesh tape, setting type compound should be used for at least the first coat. Blue bucket is "lightweight" ready mix compound. I don't use it, but some folks do...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 04-26-2010, 02:39 PM   #5
Next Time...New Build
Thanks.
For name recognition, the blue bucket is "Plus 3" ask anyone at your supply store and they will know.
RickyBobby is offline   Reply With Quote
Old 04-29-2010, 01:44 PM   #6
The blue lid is usually used as a finish or last coat.
Old ceiling replacement idsp General Discussion 12 07-25-2009 11:48 AM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
Ceiling fell down marvinjansen General Discussion 18 07-20-2008 08:08 AM
ceiling not white cart Painting 7 06-22-2008 08:32 AM
Repair of a piece of cultured stone that fell off apprentice General Discussion 2 11-26-2007 02:27 PM
