#1 |
All corners cracking
Would the fact I live 800 ft from the railroad tracks be the cause to my homes wall corners cracking? The trains come by about every 10 minutes.
#2 |
That would do it, try latex caulking, apply a small amount and wipe with you finger then use a damp sponge for a smooth finish.
The key is small amount, there's no need for any of it to be on the walls, just in the crack. |
#3 |
Super Moderator
I doubt it---All corners cracking? The same flawed technique was used on all corners--
these are the 'usual suspects' with corner failure-- Improper attachment of corner bead--not properly nailed or stapled wrong mud used--best choice powdered easy sand--- Bad framing--missing doubled outside studs wet lumber---this causes nail pops and seams to open also--I doubt this is your problem.
New members: Adding your location to your profile helps in many ways.--M-- |
| Display Modes | |
| Cracking at the Metal Bead on Drywall Corners | smata67 | Drywall & Plaster | 10 | 01-06-2013 04:01 PM |
| Corners are cracking as joint compound dries | hoffmandirt | Drywall & Plaster | 6 | 04-24-2012 10:33 PM |
| Drywall Cracking in Corners | jburchill | Drywall & Plaster | 6 | 05-21-2011 05:15 PM |
| Inside corners cracking with new paint | n0c7 | Painting | 8 | 08-02-2008 03:53 PM |
| my corners are cracking when hanging drywall in the ceiling, why? | yummy mummy | Building & Construction | 16 | 12-22-2007 01:09 PM |
