-   -   All corners cracking (http://www.diychatroom.com/f101/all-corners-cracking-168813/)
redheadedjoe 01-10-2013 11:13 PM
Would the fact I live 800 ft from the railroad tracks be the cause to my homes wall corners cracking? The trains come by about every 10 minutes.
joecaption 01-10-2013 11:40 PM
That would do it, try latex caulking, apply a small amount and wipe with you finger then use a damp sponge for a smooth finish.
The key is small amount, there's no need for any of it to be on the walls, just in the crack.
oh'mike 01-11-2013 06:36 AM
I doubt it---All corners cracking? The same flawed technique was used on all corners--
these are the 'usual suspects' with corner failure--
Improper attachment of corner bead--not properly nailed or stapled
wrong mud used--best choice powdered easy sand---
Bad framing--missing doubled outside studs
wet lumber---this causes nail pops and seams to open also--I doubt this is your problem.
