#1 |
Airtight Drywall Seams Around Existing Duct?
I want to hang drywall in my basement, but leave existing HVAC duct twisting in and out of holes in the new drywall. I can cut holes in the drywall and run the duct through the holes but I am also trying to achieve an air-tight seal.
This project is a basement workshop I want to build in one portion of an unfinished basement. I have a low ceiling and I don't want to drywall the ceiling or cover the duct work with drywall. I can re-route some ducts to avoid this new room but there will be a mandatory 18" insulated duct that comes into the shop area through one wall (near the ceiling), runs along the ceiling, then exits the opposite wall (near the ceiling). I don't care how pretty it looks, I just want to prevent saw dust from escaping the room through gaps between the drywall hole where the duct runs through. Any ideas? I was wondering if the big box stores sold some kind of giant escutcheon, similar to what plumbers use to run toilet supply pipes up through floors/walls. |
#2 |
around the ducts i would tape it so you have about a 3/16s - 1/4 inch gap and then use a product called fire caulk betwen the rock and the duct . thats what they use on some residential but mostly commercial for fire proofing.
#3 |
Super Moderator
If the ducts are square you could trim the gap with door weather stripping.
New members: Adding your location to your profile helps in many ways.--M-- |
#4 |
Drywall contractor
Yeah, the fire caulk wouldn't be a bad idea if you're concerned with a chance of a "flash fire" from the sawdust. Chances would be slim unless you're doing a full blown cabinet shop or something like that. Low expansion foam would be much cheaper and serve the same purpose. Fire caulk is not cheap....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops. |
| Tags |
drywall, duct, hvac, seams, workshop ![]() |
| Display Modes | |
| Crinkles on full wall drywall seams. Big issue? | bteudt | Drywall & Plaster | 9 | 06-30-2010 05:16 PM |
| Help!!! I can see the seams in my drywall | jusblaylock | Drywall & Plaster | 4 | 05-24-2009 02:59 PM |
| Wavy taping seams - Help (drywall taping) | newbpainter | Drywall & Plaster | 10 | 05-15-2009 10:36 AM |
| Drywall over existing ceiling? | Curious_16 | Drywall & Plaster | 7 | 04-15-2009 07:38 PM |
| Modifying existing duct work | Thurgee | HVAC | 3 | 04-05-2007 10:35 AM |
