Air Leaking From Doors - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 07:29 PM   #1
Air leaking from doors
Air comes in from the edges of patio glass door when its windy outside. If it is not windy i don't notice any air leak. Is this normal? If not, do i need to replace the doors or is there any easy way to repair this problem?
timlog is offline   Reply With Quote
Old 02-26-2010, 09:17 PM   #2
Remodeling Contractor
not normal. replace the weather stripping on the frame
Old 02-27-2010, 11:08 AM   #3
Thanks for the reply. Good that i don't have to replace the doors. That would have been a budget breaker.
Old 02-28-2010, 07:33 AM   #4
not saying that. your attempt to fix it will address that issue. It is possible you have really cheap doors. Even then you should be able to weather seal them.
Input on which doors to replace interior & exterior door with... tomas21 Carpentry 13 12-08-2009 09:32 AM
Leaking French Doors pianodude Building & Construction 8 09-05-2009 02:55 PM
Interior door swelling? jdeters79 Remodeling 9 08-15-2009 10:51 AM
Installing closet doors into un-true opening - Need ideas McCool Carpentry 8 08-12-2009 01:37 PM
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
