Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 08-08-2011, 12:34 PM   #1
Air Compressor to hopper gun
I am planning to finish my walls with a texture. I am going to buy the hopper and do it that way. But I do not have an air compressor to hook up to the hopper.
I have been looking around at all the compressors and I'm not sure which one I need for the job.
The hopper requires:
Requires air compressor with 2.4 CFM 90 PSI. So I am looking at compressors that meet that requirement, but there are a lot that do.
So, basically I'm looking for some guidance and information on which ones you guys use on your jobs.
Thank you
jburchill is offline   Reply With Quote
Old 08-08-2011, 05:13 PM   #2
I buy nothing but Quincy units. They last forever and have a high capacity versus others. It's a professional/industrial line of compressors. Avoid the Hitachi compressors like they have a disease. They don't hold up and take forever to build pressure. Consider the usual Lowes and HD tools as top of the line home owner tools but far from professional/industrial quality. But they may be all you need. If you've never owned an air compressor, buy as much of one as you can afford. You won't believe the uses it has.
TrapperL is offline   Reply With Quote
Old 08-10-2011, 10:59 AM   #3
Update to my question: here is an air compressor I was thinking about buying. This one is new, but the one I was looking at was a refurbished one for 99 bucks:
http://www.homedepot.com/Husky/h_d1/...atalogId=10053
It meets the requirements for the hopper spray gun, but is 20 gallons a good size?
Options for basement hopper window replacement 40x18 vetting Windows and Doors 1 05-06-2011 07:25 AM
Hopper? JEDI RAIN Drywall & Plaster 6 03-05-2011 05:17 AM
is there a hopper window that qualifies for the rebate? qchawkfan Building & Construction 0 01-14-2010 10:40 PM
drywall texture without gun/hopper? El Buey Building & Construction 9 03-13-2008 10:18 PM
