Advice On Some Drywall Cracks - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-08-2014, 07:05 PM   #1
Rewards Points: 34
Advice on some drywall cracks
Hi everyone, so I have these drywall cracks in my house. They've appeared slowly over the past two/three years, but haven't gotten worse in at least 6 months as far as I can tell. I didn't measure them, but I did take pictures and compare them a few times. They are almost exclusively appearing at the top corners of the windows and edge of ceiling above the windows. The only place where it isn't a straight forward split/crack I have placed my finger in the photo to show the piece that sticks out and how far.
I want to repair them but have little understanding of the best way to go about it. I'd love to do some of the work myself if possible, but my expertise lies elsewhere than home improvement. I have the time, but the $$$ is a bit of an issue atm.
Sojumonkey is offline   Reply With Quote
Old 01-08-2014, 07:13 PM   #2
Rewards Points: 13,260
Just looks like someone did a crappy job of taping the walls.
Tape has to be removed, area sanded and new paper applied with a setting compound or all purpose drywall compound.
http://www.bing.com/videos/search?q=...pair&FORM=VDRE
Old 01-08-2014, 07:16 PM   #3
Rewards Points: 34
Even given that in one of the pictures the wall sticks out further than the part above the crack?
Also, the wall in the room with the horse shoes (daughters) has texture on the walls. How do I imitate that? I don't even know what it is.
Old 01-08-2014, 07:19 PM   #4
Impossible to see anything sticking out from those pictures.
May be as simple as a screw pop.
Push on the wall to see if the sheetrock moves.
If It does, find the studs and add some screws.
No one has X Ray vision so there's no way to know how it was framed.
There was supposed to be nailers add in the inside corners to attach the rock to.
Old 01-08-2014, 07:28 PM   #5
Rewards Points: 34
True and I understand about not having x-ray vision. thanks a lot for the input I appreciate it.
Could those types of cracks be from the roof settling?
Old 01-08-2014, 07:45 PM   #6
Gymschu's Avatar
Rewards Points: 462
Could be dozens of reasons for your cracks. Poor, or insufficient framing. Leak in the roof from snow melt? Framing may have been "wet" when installed and is now drying out and twisting ever so slightly inside the wall. Moisture infiltration in the wall. Weak load bearing area. As Joe stated, could be poor taping job.
The only way to match the current texture is to find out how it was done originally. Was it done with a hopper and air compressor? Stomped with a stomping brush? Stomped and troweled? Sometimes a sponge or roller is used. It will take some investigation and even if you find the method that was used, it's still a crapshoot trying to match it perfectly.
Old 01-08-2014, 07:56 PM   #7
Rewards Points: 34
I have no doubt about it being a poor tape job regardless of the reason lol.
Trying to get a hold of the guy who remodeled this house before I bought it was a test in patience three years back (that is being extremely nice) There is no way I will be able to find out for sure after three years... sucks.
Old 01-08-2014, 08:00 PM   #8
Gymschu's Avatar
Rewards Points: 462
Looks like typical knockdown, but, again, matching it is no easy task.
Old 01-08-2014, 08:14 PM   #9
Rewards Points: 34
Yea that does look exactly like the wall. thanks
Old 01-09-2014, 08:08 AM   #10
Rewards Points: 5,974
Was the remodel a DIY? Not sure but it looks in a couple of the pics like the drywall edge is not on the stud or even no tape on the seams. Really hard to tell from pics. As Joe said press on the drywall close to the crack and see if it moves.
Old 01-09-2014, 08:55 AM   #11
Now that I look at it again I'd guess someone pieced in a bunch of small pieces at the top of that wall.
All the weakest areas are where the patches are now.
Old 02-02-2014, 12:25 PM   #12
Rewards Points: 34
Got it all patched up painting tomorrow. thanks for the help guys.
Old 02-02-2014, 12:42 PM   #13
Thanks for the update. Would appreciate letting us know what they find.
Tags
cracking walls , drywall damage , repair drywall
Drywall seam cracks - how to repair shumax12 Drywall & Plaster 14 10-19-2013 05:53 PM
Extremely aggravating drywall ceiling cracks on new home JakeAndrews Drywall & Plaster 9 08-15-2013 06:40 AM
Seeking Advice for Inside Corner Drywall Cracks/Wall Shifts Boar Drywall & Plaster 1 06-24-2011 01:13 PM
repairing drywall cracks in ceiling justin 418 Drywall & Plaster 3 12-28-2009 06:18 PM
Advice needed for filling large basement Cracks dgbehrends Building & Construction 11 11-17-2009 05:23 AM
