Advice On Pesky Reoccurring Crack In Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-27-2014, 10:12 AM   #1
Rewards Points: 26
Advice on Pesky Reoccurring Crack in Ceiling
I am a first time homeowner and haven't tackled any drywall stuff until now. I just patched a hole in my wall with a piece I cut out, then taped and mudded the seams, so I understand some basics, but nothing advanced. I have been repairing some corner beads as well.
I have an issue though that I need some advice on: my master bedroom is a pseudo-vaulted ceiling; imagine a vaulted ceiling with the top chopped off. the top is flat, but the sides slant up to the flat section. the transition between the angled part of the ceiling with the flat parts are filleted. Those transitions are cracked along almost the entire length on both sides (along the fillet length wise). I chipped out the loose mud and attempted to refill with all purpose compound, but the cracks reappeared after around a week.
It appears the previous owner patched the area, so it seems like there is some underlying issue. The ceiling in the bedroom makes a lot of noise during the day, like expanding/contracting pops. When I push on the ceiling right next to the fillets, it moves around 1/8" upward as if it's not fastened tightly to the framing. I have no attic access in this room, unfortunately.
Any ideas would be greatly appreciated.
romeyjdogg is offline   Reply With Quote
Old 01-27-2014, 10:17 AM   #2
DIY staff
Rewards Points: 7,174
The ceiling drywall is supposed to 'float' so the framing can expand and contract without lifting the drywall---
You need to remove the tape and retape the joint using Straight Flex tape--set it in Multipurpose----then top with more of the same or powdered EasySand----then top with Light weight ---
romeyjdogg (01-27-2014)
Old 01-27-2014, 10:23 AM   #3
Rewards Points: 26
Thanks for your help. It seems like I had to chip out between 1/8-1/4" of mud to get down to what looks like paper tape underneath. Does that seem normal? Also, how wide of a trench would you chip out? The width of the tape? What a pain!
Old 01-27-2014, 10:30 AM   #4
Rewards Points: 1,498
Was the old tape torn?
mikegp is offline   Reply With Quote
Old 01-27-2014, 10:51 AM   #5
Rewards Points: 26
No, it was all intact.
Old 01-27-2014, 06:52 PM   #6
Could just be too much mud on top of the tape.
Ceiling crack in sheetrock TomTom333 Drywall & Plaster 6 10-28-2012 09:13 AM
How to fix ceiling crack houseright Drywall & Plaster 18 10-11-2012 05:11 PM
20x22' detached garage ceiling joist advice amp2oo1 Building & Construction 11 08-01-2012 09:13 AM
crack and stains in ceiling under bathroom diy_dude Building & Construction 0 08-06-2011 05:52 AM
Popcorn ceiling major crack ac5me General DIY Discussions 2 11-26-2010 09:41 AM
