Advice Needed: Cutting Holes For Ceiling Cans - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-19-2014, 12:17 AM   #1
Rewards Points: 422
Advice needed: Cutting holes for ceiling cans
What is the easiest way to measure and cut the holes properly? We are going to drywall my daughter's basement ceiling, and there are 8 recessed can lights.
I don't have a spiral cutter, so I thought of using a compass to draw the circle before cutting.
Jim McC is offline   Reply With Quote
Old 01-19-2014, 05:54 AM   #2
Rewards Points: 14,026
For that small a number of holes this will work and contain most of the dust.
http://www.homedepot.com/p/Klein-Too...731/203828012#
I use a hole saw made just for can lights. It has carbide grit instead of teeth. But it's pretty pricy.
A string pulled tight and a tape measure for spacing is just one way to lay it out.
Old 01-19-2014, 06:25 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,984
If your not doing it for a living......
for a 6" can....the lid from a 1 gallon paint can is just about right. I drill a hole and then use either my sawzall or a drywall saw
Old 01-19-2014, 07:10 AM   #4
DIY staff
Rewards Points: 7,174
Buy a drywall compass----they are available where ever drywall tools are sold---they have a sharp cutter wheel--then saw an X into the center of the ring and break out the waste.
Old 01-19-2014, 08:06 AM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 596
Watch out for ceiling joists, I seem to dead center them almost every time.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
ToolSeeker (01-19-2014)
Old 01-19-2014, 08:22 AM   #6
JOATMON
ddawg16's Avatar
All you have to do is cut out a big notch for the can. One notch in a joist is not going to hurt anything.
(Disclaimer....the above comment was intended for humor only. Do NOT notch a joist like that)
Old 01-19-2014, 10:23 AM   #7
Professional
TotalHomeworx's Avatar
Haha, I think I've seen people do that before. I know I've seen plumbers cut joists for traps all the time. Scary.
Putting the pot lights in before you drywall may help with the layout but you may need a different stye of pot light. You can use a regular compass and drywall saw or buy a cheap drywall router. You will need to cut out switches and receptacles as well.
TotalHomeworx is offline   Reply With Quote
Old 01-19-2014, 01:07 PM   #8
Rewards Points: 422
Thanks guys. Harbor Freight Tools has an Electric Cutting Tool on sale for $21, plus I have a 25% off coupon. Has anyone used it? Any tips on how to use one of these to cut out can lights?
Old 01-19-2014, 03:26 PM   #9
Not sure how anyone would know without a model #, picture, something?
Old 01-19-2014, 04:50 PM   #10
Rewards Points: 422
Sorry. I don't know how to post a link. It's a cheap "drywall router".
After I put the ceiling drywall up, do I just put in a few screws before routing out the hole for can light? Then screw in the rest?
Thanks.
Old 01-19-2014, 06:47 PM   #11
Rewards Points: 6,004
You screw them in except close to the light. You know if this is what I think it is, a RotoZip in cheaps clothing, the lights have to be up first.
Old 01-19-2014, 07:10 PM   #12
DIY staff
Yep--sheet right over the can--punch the tool into the center of the can---cut until you find the edge-move the cut to the outside of the can and cut ,quickly in a clockwise direction.
Go to slow and you will overheat the cutter and it will break.
Old 01-19-2014, 07:19 PM   #13
Rewards Points: 422
Thanks. Yes, the cans are already in.
Floating floor water damage - advice needed rumiat Flooring 3 05-28-2012 02:38 PM
Advice needed: Replace corroded fitting to well pipe? lightwolf Plumbing 1 11-30-2011 07:02 PM
Subfloor Overhaul - Advice Needed kadams2345 Flooring 39 11-19-2011 01:02 AM
Buying a home - water softener advice needed before closing Hoops Plumbing 4 11-02-2011 08:40 AM
Advice needed for zone damper repair... texanfan HVAC 4 07-16-2011 08:22 PM
