Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 02-15-2010, 09:43 PM   #1
Question
Adhesive removal from drywall
I recently removed wood veneer paneling from drywall but now I have a lot of glue/adhesive patches. How can I safely remove?
JoeU is offline   Reply With Quote
Old 02-15-2010, 09:51 PM   #2
Military Mom of 4
Snav's Avatar
Oi! It aint coming off easy.
You'll have to avoid getting the drywall really wet - so soaking with a solvent might be out of the question - and a waste of time.
Are you planning on painting the walls? Are you covering the walls some other way?
If you're going to paint the walls then I'd suggest to scrape it off with a blade or putty-knife of some type, then apply drywall mud and/or tape and give it a nice professional mud/sand/mud treatment before finishing with primer/paint.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
Old 02-15-2010, 09:53 PM   #3
I would try a thin putty knife... you might even want to sharpen it a little.
Know that the adhesive will want and be succesful at pulling most of the wall board paper with it during the removal process.
Plan on some skim work when you are finished.
Big Bob is offline   Reply With Quote
Old 02-17-2010, 04:01 PM   #4
Thanks for the input. I was hoping for an easier solution. Yes my plan is to paint after removal.
JoeU
Old 02-17-2010, 05:43 PM   #5
you might very carefully try a heat gun. some of the glues used will soften up when heated and come off a lot easier.
cellophane is offline   Reply With Quote
Elmer Spray On Adhesive removal... couchie Painting 4 01-09-2010 12:15 PM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 08:44 AM
delicate adhesive removal jimmyfunk Flooring 8 01-18-2007 05:22 PM
Adhesive Removal SIE Flooring 4 07-05-2005 11:50 AM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 06:41 PM
