Adhere Drywall To Residential Studs? - Drywall & Plaster - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-08-2008, 06:01 PM   #31
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Originally Posted by johnrem View Post
ceilings need to be fully fastened with screws in the field anyways.glue would be a waste.gluing walls allows for less screws which makes for an easier and smoother finish.
In my region, screws are required by code every 12" on sheetrock to be taped, more for blue board and plaster....whether you use glue or not....
- Build Well -
Old 02-08-2008, 08:01 PM   #32
its interesting to read this thread and not have one of you experts quote any literature. every manufacturer of drywall publishes recommended installation instructions for attaching the different drywall assemblies, and if it isn't installed per the manufacturer's instructions, you face a liablility issue. Here's a sample page for a fire wall using 1/2" drywall (similar to one you might use on a house garage, only that would use a different system.
http://www.gp.com/build/PageViewer.aspx?.
In addition to this information, as some of you have stated you have local codes (which may or may not meet the manufacturer's instructions). And for UL listed assemblies, you must meet the specifications that are spelled out in the UL book of Fire Assemblies (which sometimes exceeds the manufacturer's instructions).
All of this literature spells out in detail, how far apart nails, screws, or whatever attachment methods are to be in field and on the edge, and if other means are used to attach, exactly what, how and how much.
nacko is offline   Reply With Quote
Old 02-08-2008, 08:22 PM   #33
Actually, this "expert" did quote literauture. I posted the 2006 IRC fastening schedule for gypsum panels. The "literature" http://www.gp.com/BUILD/DocumentView...elementid=3139 you quoted advised to "get some friends and use t-braces to do the ceilings." These pamphlets are good for DIY's doing weekend projects that don't have the experience/knowledge that a skilled tradesperson has acquired by actually doing the work and seeing the effects of different installation methods.
jerryh3 is offline   Reply With Quote
Old 02-08-2008, 10:02 PM   #34
its interesting to read this thread and not have one of you experts quote any literature......http://www.gp.com/build/PageViewer.aspx?.
I have no idea what that link goes to ?? (I get a blank page)
But here are two of the manufacturer's installation Guides (USG & National Gypsum:
http://www.usg.com/resources/handboo...0&sectionNum=8
http://www.nationalgypsum.com/litera...dMarX_tear.pdf
- Build Well -
Old 02-10-2008, 04:27 PM   #35
another tip...use nails (less expensive) wherever the fastener is covered with tape.use the screws in the field for better holding power and longer lasting finish (no nail pops)
johnrem is offline   Reply With Quote
Old 07-01-2008, 09:33 PM   #36
Newbie Here...
OFF TOPIC sort off. I live in Arizona were all wall are rounded corners and textures walls. I am looking to have square corners and smooth walls. Is it possible or feasible to place square corners over the round and re-float the walls to smooth? Or does all of the drywall need to come down and start from scratch???
Thanks guys.
2bShawn is offline   Reply With Quote
Old 07-02-2008, 06:37 AM   #37
Originally Posted by 2bShawn View Post
Newbie Here...
Thanks guys.
Hi Newbi. Just to help you out:
Generally, it is best to start a new thread to ask such a question. You will get more responses, than attaching a question onto an older thread, that discusses something different.
As far as your question goes: Standard metal corner bead is not the way to go. Because of the rounded edges (there are different dimensioned radiuses), metal corner bead's edges really can't reach the flat portion of the wall and align with it.
I suggest a No-Coat, pre-formed plastic and paper outside corner material. It can be found at drywall supply houses. It is installed using joint compound. ( Ifeel that this is the best method for what you wish to do): http://www.no-coat.com/.docs/pg/10136
- Build Well -
Old 07-02-2008, 09:20 AM   #38
Thanks...
Thanks for the thread tip and for the advice for the corners...saved me a lot of work! Have a great 4th of July!
Drywall over drywall? And a bonus flooring question! perpetual98 Remodeling 18 01-02-2008 11:36 AM
Attaching kitchen cabinets directly to studs with no drywall between nrabate Carpentry 7 08-28-2007 10:01 AM
drywall onto uneven walls? johnny331 Remodeling 5 06-28-2007 08:59 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-11-2006 12:10 AM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 08:11 AM
