Adhere Drywall To Residential Studs? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-07-2008, 06:06 AM   #1
Question
Adhere Drywall to Residential Studs?
I just heard some drywallers put glue on the studs on residential work, then screw on the drywall. I had never heard of that before though.
What's the deal on using adhesive behind drywall?
TomBrooklyn is offline   Reply With Quote
Old 01-07-2008, 07:05 AM   #2
Building and plumbing
USP45's Avatar
Rewards Points: 150
It gives a more secure bond, helps stop screws or nails from poping out should the studs move.
USP45 is offline   Reply With Quote
Old 01-07-2008, 03:38 PM   #3
I've never heard of a good drywall hanger not using glue.
jerryh3 is offline   Reply With Quote
Old 01-07-2008, 05:34 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
It's a regional thing.
We have a division in our company that has been doing drywall since the early 80's, as well as knowing many, many other drywallers in our area.
Neither we, nor any one of them have ever used, nor been required to apply adhesives for sheetrock. That includes it not being listed as part of any installation procedures in the hundreds upon hundreds of plans that we have reviewed over the years -(Residential, offices, apts, condos, hospitals, schools, industrial, etc....)
We have never had any failures on walls because of this. It is also not required by any codes in our area.
As stated, it's a regional thing.
- Build Well -
Old 01-07-2008, 07:02 PM   #5
Whatever works. I find that when using glue, we reduce the number of screws used. We typically go with: Ceilings, two in the field 16" o.c, three 24" o.c, and only one in the field on the walls. This is assuming the walls/ceilings are straight and true.
Old 01-07-2008, 07:12 PM   #6
I don't know where you hang your sheetrock, but in our region, Building Codes require one screw every 12", regardless of adhesive use (Building Code Materials Fastener Schedule).
- Build Well -
Old 01-07-2008, 07:31 PM   #7
Maryland. No code enforcement on panel fastener schedule.(Or at least no inspector has ever said anything for the past 1000+ homes). So I guess you are right about the regional thing.
Old 01-08-2008, 07:02 AM   #8
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I have done projects in various parts of county. Some use glue, others don't. I subed out the drywall on my basement project. The "standard" from the sub I went with was glued, nailed at top edge and screwed. I didn't even question it.
Brik is offline   Reply With Quote
Old 01-08-2008, 07:54 AM   #9
RippySkippy's Avatar
Our area (central Iowa) requires 5 in the field, and 6 on ends, glue doesn't change the mechanical fastener req's. I had a house '73 version that had the glued drywall, with 2 screws in the field. Nearly every sheet in the house had loose drywall...meaning you could push the drywall back to the stud. A kitchen reno revealed that the glue held tight...the paper though let go of the DW. Every sheet had a stripe on the back where every bit of paper pulled off where it was glued to the stud. I pray they are making the DW better these days! I was never sooooo glad to get out of a house....every corner brought another joyful nugget....
RippySkippy is offline   Reply With Quote
Old 01-08-2008, 08:06 AM   #10
Hi Jerry,
I'm not sure if I'm understanding you right. Are you saying you attach 4' x 8' drywall to a ceiling with 2 screws and on walls with one screw, not counting the edge screws? BTW, how many screws do you put on the edges? And what would thickness of sheet rock are you using?
Old 01-08-2008, 08:09 AM   #11
mt232's Avatar
Did the glue come along when nails were still being used?
I wish my old nailed drywall had glue, or screws.....as my add a level is almost complete, almost every ceiling on the 1st floor has cracked, shifted, or at least had most nails pop out.......
mt232 is offline   Reply With Quote
Old 01-08-2008, 02:46 PM   #12
Originally Posted by TomBrooklyn View Post
Hi Jerry,
1/2" 4' X 12' sheets mostly. 5/8" in garages with common walls. Yes, a good bead of glue with two screws in the field(3 w/ 24" o.c. ceilings) and one on the walls. The edges usually get two on the first sheet and three on the sheet that butts against that. I know this goes against what most fastner schedules call for, but in the 30+ years my father hung drywall and the ten I worked with him, we never received a complaint about the quality of hanging or the methods we used. Of course this was only with straight and true walls. We always increased the fasteners if needed(bowed, twisted, damaged, excessive insulation, thick strike plates.) And again, this is only one method from one person. People have to use whatever they feel comfortable doing and what their local code calls for.
Old 01-08-2008, 05:36 PM   #13
That's not neccessarily a result of using screws and no glue.
If the sheetrock is tightly affixed to the framing ......and the framing settles, shrinks, moves, shifts, etc......the more damage you will have on the drywall surface.
Example: This is especially the case if you have truss systems in your ceiling and the plates flex seasonally. Tightly affixed sheetrock will get wrecked, with all kinds of cracks and popped screws.
Also Link Discussion: http://www.contractortalk.com/showth...light=adhesive
- Build Well -
Old 01-08-2008, 05:46 PM   #14
This is very true. On wide houses with truss roofs, we usually hold back the screws near the interior walls 16". This allows a little truss uplift and prevents the corner tape from splitting between the wall and ceiling. At least that's the way it's supposed to work.
Old 01-08-2008, 07:04 PM   #15
2006 IRC schedule
Dusted off the 2006 IRC. Sorry for the bad scan.
Drywall over drywall? And a bonus flooring question! perpetual98 Remodeling 18 01-02-2008 10:36 AM
Attaching kitchen cabinets directly to studs with no drywall between nrabate Carpentry 7 08-28-2007 09:01 AM
drywall onto uneven walls? johnny331 Remodeling 5 06-28-2007 07:59 AM
nails and staples missed studs in garage dingler44 Building & Construction 1 10-10-2006 11:10 PM
Framing and Drywall questions haysdb Building & Construction 5 11-04-2005 07:11 AM
