Adding tile to a bowed wall
Yes, adding furring strips (on,, not across, the studs) will let you make the overall wall more flat. Although I have not seen example, I have the impression that bowing of the wall surface would be more noticeabvle with tiles as opposed to just a painted wall.
You may need furring strips of varying thicknesses depending on the nature of the bowing. For a vertical pipe that sticks out, most likely each strip itself would be of a uniform thickness but if the studs themselves are cureved you may need to use myriads of paired wedges on the studs to achieve a flat wall.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
