Adding tile to a bowed wall
Dry wall in the bathroom is bowed or pushed out by the vent
pipe inside the wall. There is no way to adjust the position of the vent pipe. I need to straighten the dry wall to install tile on the wall. Would adding firring strips to the studs that are set back help to create a level wall? |
How wide is the entire wall length and what is the (outward) measurement beyond plane?:)
Yes, adding furring strips (on,, not across, the studs) will let you make the overall wall more flat. Although I have not seen example, I have the impression that bowing of the wall surface would be more noticeabvle with tiles as opposed to just a painted wall.
You may need furring strips of varying thicknesses depending on the nature of the bowing. For a vertical pipe that sticks out, most likely each strip itself would be of a uniform thickness but if the studs themselves are cureved you may need to use myriads of paired wedges on the studs to achieve a flat wall. |
| All times are GMT -4. The time now is 05:51 PM. |
