Adding Texture To Ceiling - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-02-2012, 03:23 PM   #1
Adding Texture to Ceiling
I know...not another one of these posts. I've searched this site, and searched the internet like crazy but couldn't find an answer and my head is about to explode.
What level of finish do I need to do to the ceiling before adding texture to it? Was thinking level 2 would be sufficient, but don't want to see the seams after I've added it...
Thanks for the help!
MLayden is offline   Reply With Quote
Old 08-02-2012, 06:15 PM   #2
Rewards Points: 512
i do a tape coat then do a 2nd coat with a 10" knife. i prime the ceiling then spray my texture
princelake is offline   Reply With Quote
The Following User Says Thank You to princelake For This Useful Post:
MLayden (08-02-2012)
Old 08-02-2012, 06:28 PM   #3
Thanks. Was thinking that I could get away with that.
I know there's quite a debate about priming before...so I won't ask that question and open up a can of worms.
Old 08-02-2012, 06:56 PM   #4
Rewards Points: 13,254
If you check more on this site and about any DIY site you will see hundreds of people asking how to remove texture and almost no one asking how to apply it.
Next to imposable to clean, hard to paint. very hard to ever do any patches if there's ever a leak or any damage.
But it's your house.
Old 08-08-2012, 11:16 AM   #5
I realize that, but the wife wants the ceilings to match the rest of the house...tried to reason with her to no avail!
Old 08-12-2012, 09:47 PM   #6
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Never less then a level 3.
Sir MixAlot is offline   Reply With Quote
Old 08-21-2012, 10:56 AM   #7
Good news! Worked on the wife enough that we are now painting the ceiling vs spraying texture!
Old 08-29-2012, 04:20 PM   #8
Drywall contractor
Rewards Points: 1,070
Normally in new construction it's tape, bed coat ant texture. USUALLY does a good enough job. Glad you decided to go slick....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Adding Ceiling fan without wall switch bennyhann Electrical 4 01-02-2012 04:19 PM
Using Wall And Ceiling Texture as Joint Compound? Murp-the-Surf Drywall & Plaster 6 07-30-2011 06:14 PM
HELP match my ceiling texture ksdriller Remodeling 1 11-09-2009 03:59 PM
Ceiling Texture Matching MJBhoya Painting 3 02-08-2009 11:04 PM
Adding A Ceiling Fan To Living Room jte1130 Electrical 1 05-28-2008 04:05 PM
