07-22-2012, 09:47 AM
#1
9' ceilings
it is said that drywall should be hung horizontaly. but with 9' ceilings, and 4' drywall, there is 1' left over.
should i just cut the extra 1' , for the top or bottom ? or just get longer drywall and lay it vertically ?
thanx
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
07-22-2012, 09:55 AM
#2
Super Moderator
9' ceilings
Add a 1 foot strip ---or install vertically--or ,if the job is big enough, go to a drywall supplier and buy 5 foot wide sheets.
07-22-2012, 10:14 AM
#3
9' ceilings
well, it is basically my whole house. but i am doing it 1 room at a time. and i am getting the DW from either HD or manards, as they are on my way home from work = i use less gas and time, that way. 5' drywall would be hard to fit in my truck.
my understand, is that, other than making the seams harder to see(horizontal). there really is no difference in how its layed, correct ?
07-22-2012, 10:23 AM
#4
Moderator
9' ceilings
Menards has 54" sheets for 9' walls.
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
07-22-2012, 10:38 AM
#5
9' ceilings
interesting. thanx  . i will have to measure my truck, 54" would be close.
07-22-2012, 10:44 AM
#6
9' ceilings
just measured truck. 52" is all it could do  . 95 s10
07-22-2012, 10:46 AM
#7
Super Moderator
9' ceilings
Even if you have to rent their truck or pay for delivery you will be money ahead---
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
07-22-2012, 10:53 AM
#8
Moderator
9' ceilings
It would be pretty easy to build a temp support in the bed to get you to wheel well height to haul the sheets.
07-22-2012, 11:14 AM
#9
9' ceilings
the wheel wells are not the problem. the bed total width is the problem. i could build a frame to raise the dw over the bed.
but, what about the vertical seam thing ?
07-22-2012, 11:30 AM
#10
Moderator
9' ceilings
It’s lot easier working on one seam right in front of you then multiple seams that have you from on your knees to up a ladder.
The Following User Says Thank You to kwikfishron For This Useful Post:
07-22-2012, 11:34 AM
#11
9' ceilings
i didn't think of that. thanx
i just thought of a way to haul it, using just 2 2x4's and 4 eye bolts and straps. so this is what i will do.
The Following User Says Thank You to Fix'n it For This Useful Post:
07-22-2012, 06:34 PM
#12
I make love to my walls
9' ceilings
Rather than wasting time building something for your truck, rent a uhaul flatbed or whatever for 19.95 and get it over with. Get the 54" drywall and lay them down. Even if you're doing one room at a time order the drywall for the whole job and stock it in one room or the garage and you'll only have to haul the sheets once
07-22-2012, 07:34 PM
#13
9' ceilings
Man go to a building supply dealer and tell them what you need most deliver free of charge!
The Following User Says Thank You to Nailbags For This Useful Post:
07-22-2012, 08:00 PM
#14
9' ceilings
$19.95 x, oh, say, 10 trips = $200.
1 2x4 cut in half = $3
you do the math. i ain't made out of money. my tools have to earn their keep. and that also means my truck.
i don't want 30-40-?? sheets of drywall sitting around getting in my way.
07-22-2012, 08:05 PM
#15
Moderator
9' ceilings
If you're going to haul it yourself cut two 2x4's so you have 4 stickers. 2 stickers isn't quite enough imo.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
