7" Ceilings Drywall Vertical Or Horizontal - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-19-2013, 08:26 PM   #1
bryanp22's Avatar
Rewards Points: 288
For ceilings lower than 8 feet should I drywall with the sheets vertical or horizontal? My ceilings are 7 feet high.
bryanp22 is offline   Reply With Quote
Old 09-19-2013, 08:30 PM   #2
Rewards Points: 13,216
Age old question.
Can be done both ways but I would go horizontal and use 12' sheets.
Make sure to install ceiling first then top sheet first and leave 1/2 space at the bottom.
Old 09-19-2013, 08:33 PM   #3
bryanp22's Avatar
Rewards Points: 288
I'm leaving ceiling exposed so does that impact the drywall direction for wall? 12 foot sheets won't fit down the stairs.
Old 09-19-2013, 08:43 PM   #4
Why would you leave the ceilings open?
Old 09-19-2013, 09:10 PM   #5
bryanp22's Avatar
Rewards Points: 288
Don't want like the closed off look with 7 foot ceilings. We like the painted black exposed ceiling look.
Old 09-19-2013, 09:32 PM   #6
Rewards Points: 216
no doubt = vertical. just MAKE SURE the sides land on a stud, 16"oc. or you can cause yourself taping problems.
Fix'n it is offline   Reply With Quote
Old 09-20-2013, 09:05 PM   #7
Registered User
Rewards Points: 5,180
Check with your fire Marshall/building official, may require drywall for fire control as per code; http://www.cbc.ca/news/canada/windso...or-joists.html
Double the burn time; http://www.gypsum.org/wp/wp-content/.../11/225-08.pdf
Gary
Old 09-20-2013, 10:06 PM   #8
bryanp22's Avatar
Rewards Points: 288
Already ran by the inspector they are fine with it.
The Following User Says Thank You to bryanp22 For This Useful Post:
Gary in WA (09-21-2013)
Old 09-21-2013, 07:27 AM   #9
DIY staff
Rewards Points: 7,174
Vertical requires perfect stud placement--or lots of additional blocking----
There is a J-channel available that will give you a nice finished edge at the top---you might want to use it so the raw edge of the board is covered.
princelake (09-21-2013)
Old 09-21-2013, 08:33 AM   #10
bryanp22's Avatar
Rewards Points: 288
We are going to use crown molding at the top edge.
oh'mike (09-21-2013)
Old 09-21-2013, 10:54 PM   #11
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
My vote is for the horizontal install. Less seams too.
Sir MixAlot is offline   Reply With Quote
The Following User Says Thank You to Sir MixAlot For This Useful Post:
ToolSeeker (09-22-2013)
Old 09-21-2013, 11:03 PM   #12
Registered User
You may still be required to insulate the rim joist areas to (floor) R-30 or at least the same as (walls) R-5 fb and R-13 cavity (above and below); http://energycode.pnl.gov/EnergyCode...tate=Wisconsin
http://www.buildingscience.com/docum...l_seal_rev.pdf
Thick enough; http://www.buildingscience.com/docum...r-requirements
http://www.buildingscience.com/docum...apor-retarders
Or just leave it out; similar to basement above-grade; http://www.quadlock.com/technical_li...Insulation.pdf
Gary
Old 09-21-2013, 11:05 PM   #13
bryanp22's Avatar
Rewards Points: 288
I'm doing roxul then 2 inch xps on top. Code says no fire barrier is required on top of xps in rim joist.
Old 09-22-2013, 11:28 AM   #14
Rewards Points: 4,792
Crown molding with no ceiling? OK - interesting.
Do some drawings on paper to estimate the differences between horizontal and vertical. For each, determine the total number of feet of joints, and then the total feet of butt joints. Whichever gives you the lower numbers - that's how you should install.
Don't get married to finished on a stud edge. There are products and techniques that can help with that, such as
http://www.trim-tex.com/product_cata...wproduct&id=93
jeffnc is offline   Reply With Quote
Old 09-22-2013, 11:18 PM   #15
Registered User
Could you site that code reference please? You are under the IBC; http://www.reedconstructiondata.com/...des/wisconsin/
In a finished basement, IMO, it needs a thermal barrier, ignition barrier or sprinklers to meet code; http://publicecodes.cyberregs.com/ic..._26_sec003.htm
Gary
toilet vent- horizontal vs vertical? samuel11 Plumbing 4 08-20-2010 05:41 PM
Vertical or horizontal installation Tom241953 Drywall & Plaster 7 07-20-2010 08:53 PM
Drywall - Horizontal or vertical slinku2020 Drywall & Plaster 27 04-08-2010 01:40 PM
Need Drywall Help looking4ideas Remodeling 1 04-01-2008 07:27 AM
installing drywall to 10 ft vertical walls markt59 Building & Construction 6 01-16-2008 08:09 PM
