5/8" Drywall On Steel Studs 24" OC - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-08-2009, 12:37 PM   #1
5/8" drywall on steel studs 24" OC
I have a question about proper installation of drywall on steel studs that are 24" OC.
Is there any difference if I install it horizontaly or verticaly?
Is it safe to install it horizontally with studs 24" OC.
Thanks Charles
Charles_cz is offline   Reply With Quote
Old 06-08-2009, 12:55 PM   #2
How tall are the studs?
redline is offline   Reply With Quote
Old 06-08-2009, 01:07 PM   #3
Double post... not sure how to delete it..
Old 06-08-2009, 01:08 PM   #4
That's the tricky part. It's 9'. I have to go above susspended ceiling height which is 8'. Can I possibly get 9' 5/8" drywall?
One of the walls will be build from 1 5/8" steel studs with 5/8" drywall.
Old 06-08-2009, 04:12 PM   #5
Yea you could stand up 5/8" should be fine. If it was 1/2" forget about it. You should be able to lay it down fine just start with 4x8 or 4x10 then put a 12" or 16" what every you need Rip on top of that and then use the other full sheet on top of that rip. If your a good taper or have one to tape you wont notice that bastard joint in the middle.
Yes you can get 9' board I'm not sure if HD carries it but a supply house will or can get it. You can get it in what ever size you need from what I know. 8'6",9'6" etc
Would I use 5/8" on 24" Centers No. I would go up to 3/4" or double layer that rock. IMO
Good luck
BDestroyer8418 is offline   Reply With Quote
Old 06-08-2009, 04:53 PM   #6
Registered User
Rewards Points: 5,266
From the maker: Walls:
3/8 (9.5) Perpendicular 16 (406)
or Parallel
1/2 (12.7) Perpendicular 24 (610)
or Parallel
5/8 (15.9) Perpendicular 24 (610)
or Parallel
Page 3, Table 1: http://www.gypsum.org/pdf/GA-216-07.pdf
Storing, hanging, nailing, screwing, priming before texture, etc.
Be safe, G
Old 06-08-2009, 05:45 PM   #7
Well, it's designed by architect. Believe me, I have hard time to believe that I will have to put 1 5/8" steel studs 24" OC with 5/8" drywall and then I will have to wall mount sink for ADA compliant bathroom.
My question is, if either method (vertical or horizontal) correct or incorrect? It's not home project. It's small commercial project.
I guess GBAR answered my question and either is fine.
Old 06-08-2009, 05:49 PM   #8
or Parallel
or Parallel
or Parallel
Be safe, G
Thank GBAR, I was looking for this and could not find it. I will read thru that.
Old 06-08-2009, 05:50 PM   #9
Yea I don't no why alot of them do that with the 24" O.C. There's always a little wave in the wall because of that span but maybe it's just me. Are you furring out a wall since your using 1-5/8" studs.
Whatever is easier on you both are fine.
Old 06-08-2009, 07:16 PM   #10
Drywall and Painting Pro
Sir MixAlot's Avatar
Rewards Points: 876
Here in Florida "commercial" = vertical 5/8" for fire code.
Sir MixAlot is offline   Reply With Quote
Old 06-08-2009, 09:10 PM   #11
Rewards Points: 162
5/8" rock on metal studs at 24" oc is pretty standard in commercial construction. At that spacing, I would recommend either 22 or 20 gauge studs in lieu of the standard 25. It's a relatively small cost premium, but worth it for a stiffer wall.
As far as horizontal versus vertical, I think horizontal gives you a better looking finished product. I've seen sheets installed vertically in areas that get a lot of natural light, and the seams stand out a little more.
As far as sinks, etc mounted to the metal studs, there should be wood blocking installed between the studs. Heaver items like wall hung water closets will ride on a metal carrier mounted in the stud space.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 06-08-2009, 09:39 PM   #12
Actually there will be two walls. One right against the masonry exterior wall from 3 5/8" steel studs insulated, then 2 1/2" air space and another wall from 1 5/8" steel studs with two vents to keep air moving thru the wall if that makes sense.
It is going to be plumbing wall so I assume it is precaution to prevent freezing conditions.
1 5/8" to steel stud to keep as much space as possible? Sometimes 2" make difference.
ENT in steel studs? krazni Electrical 4 01-15-2009 02:04 AM
insulating between steel studs drewhart Building & Construction 1 09-05-2008 09:07 AM
Adhere Drywall to Residential Studs? TomBrooklyn Drywall & Plaster 37 07-02-2008 09:20 AM
Steel Studs ? Steve Carpentry 3 11-24-2006 06:10 AM
