3/8 Vs. 1/2 - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-20-2011, 03:41 PM   #1
Rewards Points: 1,062
3/8 vs. 1/2
basic question: is 3/8 used for ceilings while 1/2 is used primarily for walls?
thanks
Old 05-20-2011, 04:16 PM   #2
Old School
Willie T's Avatar
No, 5/8 for ceilings.
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
amakarevic (05-20-2011)
Old 05-20-2011, 04:18 PM   #3
Framing Contractor
Rewards Points: 120
3/8 can be used for curved walls or on repair work. It can also be applied directly over plaster.
sixeightten is offline   Reply With Quote
The Following User Says Thank You to sixeightten For This Useful Post:
Old 05-20-2011, 04:25 PM   #4
why is thicker/heavier used for ceilings? i would expect it would be better if it is lighter.
Old 05-20-2011, 04:33 PM   #5
NACE Coating Inspector
mustangmike3789's Avatar
5/8 is thicker/heavier/more ridged. 3/8 will sag between every rafter.
mustangmike3789 is offline   Reply With Quote
The Following User Says Thank You to mustangmike3789 For This Useful Post:
Old 05-20-2011, 04:34 PM   #6
thanks. makes perfect sense now.
Old 05-21-2011, 03:40 PM   #7
3/8's should only be used for strange repairs and curved walls. Everything else should be 1/2" or 5/8"s.
PS.
1/2" is perfectly fine for ceilings, if your joists/trusses are 24" on center you need to use 1/2" CD board.
5/8" is good for everything but then there are drawbacks, such as cost, more work to install, acoustically it will change the way a room sounds and if used on both sides of a wall it may cause difficulties with trimming your doors.
dberladyn is offline   Reply With Quote
The Following User Says Thank You to dberladyn For This Useful Post:
amakarevic (05-23-2011)
Old 05-22-2011, 10:15 AM   #8
Drywall contractor
Rewards Points: 1,070
1/2" is acceptable on ceilings if framing is 16" o.c., 5/8" for 24" o.c. framing.....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
The Following User Says Thank You to bjbatlanta For This Useful Post:
Old 05-22-2011, 10:30 AM   #9
Rewards Points: 1,010
Unless there is a requirement for a fire rating or some other assembly. SFR's using TJI's will often be required to use 5/8" type X drwall because engineered lumber burns much more rapidly than nominal sawn lumber. Some areas have recognized the use of fire rated 1/2" GWB, but this is not universal
I'm sure that BJ knows this
Anti-wingnut is offline   Reply With Quote
Old 05-22-2011, 10:57 AM   #10
Do you not have "CD" board in your area? 1/2" CD board is designed for 24" spans.
As for fire ratings, that's a seperate issue and code specific to different areas.
Dan
Old 05-24-2011, 09:38 PM   #11
Rewards Points: 172
Just for reference, I used 3/8 on my garage walls, and it seems strong enough. I know...lots of people don't recommend it, but it worked, it's lighter, and cheaper, and it was just my garage.
nateshirk is offline   Reply With Quote
Old 05-24-2011, 09:41 PM   #12
Framing Contractor
Rewards Points: 120
Cheaper? I think not. At least not in cost. It is a cheaper (inferior) product though.
Old 05-24-2011, 09:43 PM   #13
Funny thing is, as per modern fire ratings, you should have used 5/8 Type X or 1/2 fire rated board in your garage.
Old 05-25-2011, 10:42 PM   #14
Rewards Points: 172
I'm sure that's what they used for the exterior walls of the house. I just finished the rest of the garage.
Old 05-25-2011, 10:44 PM   #15
The garage is the most flammable spot in the house
