3/8 vs. 1/2
basic question: is 3/8 used for ceilings while 1/2 is used primarily for walls?
thanks |
No, 5/8 for ceilings.
3/8 can be used for curved walls or on repair work. It can also be applied directly over plaster.
thanks. makes perfect sense now.
3/8's should only be used for strange repairs and curved walls. Everything else should be 1/2" or 5/8"s.
PS. 1/2" is perfectly fine for ceilings, if your joists/trusses are 24" on center you need to use 1/2" CD board. 5/8" is good for everything but then there are drawbacks, such as cost, more work to install, acoustically it will change the way a room sounds and if used on both sides of a wall it may cause difficulties with trimming your doors. |
1/2" is acceptable on ceilings if framing is 16" o.c., 5/8" for 24" o.c. framing.....
I'm sure that BJ knows this |
As for fire ratings, that's a seperate issue and code specific to different areas. Dan |
Just for reference, I used 3/8 on my garage walls, and it seems strong enough. I know...lots of people don't recommend it, but it worked, it's lighter, and cheaper, and it was just my garage.
Cheaper? I think not. At least not in cost. It is a cheaper (inferior) product though. |
Funny thing is, as per modern fire ratings, you should have used 5/8 Type X or 1/2 fire rated board in your garage.
I'm sure that's what they used for the exterior walls of the house. I just finished the rest of the garage.
The garage is the most flammable spot in the house
| All times are GMT -4. The time now is 03:56 AM. |
