3/8 For Basement Bathroom Cieling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 06-03-2011, 10:20 AM   #1
Rewards Points: 79
3/8 for basement bathroom cieling?
We're in the process of redoing our basement bathroom courtesy of a flood and one of the things we're doing is the ceiling. They had some old fiber/cardboard tiles there that were starting to come down. So we ripped them down and also the strapping/lath that they had holding it up.
One other thing is there is real limited space in this bathroom. I'm 6'2" and my head almost hit the ceiling before. I'm afraid if we go with the plan which is firring strips across the floor joists above + 1/2" I may have to duck when going into the bathroom.
Since I'm going across the joists (have to in order to clear water/electrical), 16" OC is not an issue for me to do. Given this, could I get away with the 3/8 for the ceiling? It doesn't have to be strong since it's a ceiling, just has to not sag.
itguy08 is offline   Reply With Quote
Old 06-03-2011, 01:03 PM   #2
Registered User
Rewards Points: 5,212
You should check locally. 1/2" drywall is minimum for applying a water-based texture; http://publicecodes.citation.com/ico...002_par010.htm
Gary
Old 06-03-2011, 05:29 PM   #3
Rewards Points: 79
Gary
Thanks - we don't plan on doing any textured ceilings, just regular old paint.
Old 06-03-2011, 05:58 PM   #4
MikeKy55's Avatar
Rewards Points: 254
I would never give up the strength for 1/8" in height. You would have to measure it to know the difference. But thats my opinon.
MikeKy55 is offline   Reply With Quote
Old 06-03-2011, 05:59 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Isn't 5/8" the minimum thickness required for fire codes?
XXX
Old 06-04-2011, 08:53 AM   #6
Drywall Texture Pro in Fl
stoner529's Avatar
Rewards Points: 154
Fire codes vary. for instance, in some counties in Florida such as orange and seminole, code requires 5/8" sheetrock, unless you use the more expensive 1/2" sag resistant board.
Do as you will, but i would at least go with 1/2" for the ceiling.
how to remove popcorn
stoner529 is offline   Reply With Quote
Old 06-05-2011, 12:24 PM   #7
Local codes for me only require fire rated ceiling if it is separating two units. So for single family home, the ceiling does not need fire rated drywall. In which case the only concern is rigidity. For 16"oc, anything less than 5/8 will sag, unless using special boards
acerunner is offline   Reply With Quote
Old 06-06-2011, 01:21 PM   #8
AfterDinnerDIY.com
I completely agree...
AfterDinner is offline   Reply With Quote
Old 06-07-2011, 09:27 AM   #9
Rewards Points: 79
Thanks for all the responses. We're going to go with the firring strips 12" OC and 1/2 sheetrock for the ceiling.
HRV With Bathroom Stale Air Pickup??? 1BadBoy Building & Construction 10 06-17-2011 03:17 PM
1886 Eastlake - add upstairs bathroom or expand downstairs bath?? TOTALN00B Plumbing 1 05-14-2011 10:54 PM
How to select appropriate Bathroom Lighting crescentharbor1 Kitchen & Bath Remodeling 1 02-28-2011 10:47 PM
Basement bathroom wiring mess. Little help. trailblazer1229 Electrical 15 02-16-2010 10:29 AM
Bathroom cieling moisture problem! DH1212 General DIY Discussions 12 04-01-2009 01:01 PM
