3/4" Shim Above Window To Ceiling? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 01-03-2014, 12:21 AM   #1
Rewards Points: 220
3/4" Shim above window to ceiling?
Hi group, had a major tile job repair, and found out my drywall is out of whack as well as the tiled wall.
anyway, I will take pictures tomorrow, the wall bows out as I go from the bathroom window up to the ceiling about 3/4" the tile guy shimmed the wall with 2x4" we cut and added to the existing 2x4".
Wondering if anyone can help me determine if I can do this myself 2' vertical about 4' wide and if this is possible by me, would a router with a 1/8" drywall bit or an multipurpose tool with a plunger cut tool or a circular cut bit. I would say as home owner handy man type I am about a 7 in skill level.
My thoughts are to use one of the tools cut along the ceiling line then either down at the wall end or before depending on the bowing and then above the window "high spot" shim to plumb " then replace the drywall, tape, and mud to finish.
Is there something I am missing? Thanks Dave
dfphoto is offline   Reply With Quote
Old 01-03-2014, 05:27 AM   #2
DIY staff
Rewards Points: 7,174
We need that picture----I'm having a hard time picturing the problem.
Old 01-03-2014, 10:29 AM   #3
Rewards Points: 5,974
Agree with Mike.
Help with a Window Removal/Install anthony232 Windows and Doors 12 09-18-2013 04:39 PM
Pass Through Counter Top & Window Setup Questions miamicuse Building & Construction 6 05-25-2013 08:13 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
Removing a window for painting... JJDoherty General DIY Discussions 6 08-31-2010 08:39 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 07:15 AM
