3/4"-1" Gap At Joint - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 02:21 PM   #1
3/4"-1" Gap at Joint
I am opening up my 1952s home and it is requiring redrywalling in a few places. Because of the age of the home, the drywall/plasterboard combo is about 3/4" thick. There are a few spots (one in particular) where the gap between the wall drywall and ceiling (where I took a wall out) is between 3/4-1". What is the best way for me to make this joint? Can I just use a corner bead and load it up with compound to fill the gap or should I cut a little 1" strip of drywall to fill that space?
Also, is it possible for me to just mud over a 2x4 that is flush with the drywall around it or do I have to figure out some way to put drywall over the top of it first? Can I just put a couple layers of mesh tape on it?
Jim
OddBuffalo is offline   Reply With Quote
Old 11-03-2011, 11:58 AM   #2
Next Time...New Build
Rewards Points: 150
FIll in the gap with drywall strips if you can. That is a big gap to try to mud, which would be more prone to cracking.
It might be too late, but when removing the old plaster, just fur the wall to be drywalled with 1/4" plywood strips. This brings the new surface back to the original 3/4 thickness. (1/2" drywall + 1/4" furring strip)
Don't mud over a 2x4. I'm having a hard time imagining why you would have drywall up against a 2x4 like that. Take the extra time to do it right.
RickyBobby is offline   Reply With Quote
Old 11-03-2011, 03:06 PM   #3
Thanks so much for the reply. That's kind of what I figured, but wanted to make sure I couldn't get by with the easier way first.
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
How to attach 3/4" conduit to 1" hole? erickotz Electrical 6 08-24-2011 10:04 PM
Can I go up from 3/4" metal gas pipe to a 1" and then back down? Philip_Soldat Plumbing 3 11-09-2009 09:47 AM
1" copper vs 3/4" copper Plumbvoltage Plumbing 3 09-04-2009 03:11 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
