20 Min Mud In Full Bucket Of Water To Prevent Drying? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-20-2014, 03:41 AM   #1
Rewards Points: 133
20 min mud in full bucket of water to prevent drying?
suppose you mix 2 gallons of 20 minute drywall mud in a 5 gallon bucket and there's like 3 cups of mud left in the bucket while you're busy doing something else. Can you fill the bucket with water before it cures and then add more plaster powder to the water and re-use the previous mud that you watered down, or is it a sort of one-time use thing and you have to throw away what you don't use within 20 mins? thanks.
gunner666 is offline   Reply With Quote
Old 09-20-2014, 06:05 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 2,454
no
chrisn is online now   Reply With Quote
Old 09-20-2014, 06:11 AM   #3
Rewards Points: 2,852
Xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Old 09-20-2014, 06:16 AM   #4
Top of page 2
Paint brushes can be kept from drying by suspending them in a 5 gal. bucket with a lid and a cup of water.
http://www.drywallschool.com/mud2.htm
Old 09-20-2014, 09:01 AM   #5
Rewards Points: 1,844
Hot mud will set submerged in water so the answer is no.
mako1 is offline   Reply With Quote
Old 09-20-2014, 09:26 AM   #6
Rob
Robpo's Avatar
Rewards Points: 768
I clean everything that has mud on it before mixing a new batch.
Robpo is offline   Reply With Quote
Old 09-20-2014, 11:20 AM   #7
Robpo: You have to .Especially with hot mud unless you want crunchies in the next batch.That always PMO
Old 09-20-2014, 11:53 AM   #8
Rewards Points: 3,590
Hot mud will still set up under water since it drys by a chemical reaction not evaporation. Is a bad idea to even add water to it once it starts to set up on you if you make it too thin it will be brittle when it dries. May get by adding a little once.
Old 09-20-2014, 12:18 PM   #9
Maybe.But not a good idea.Don't ask me how I know this! I hate to ad a little after a few minutes even on 45 or 90.
Old 10-16-2014, 11:16 PM   #10
Rewards Points: 133
Thanks. I'd still fill the bucket real quick after the last amount is used instead of having to scrape it all out for the next batch because i'd be final touching/sponging the mud that's been applied probably longer than it takes for the leftovers to dry in the bucket.
Old 10-17-2014, 11:25 AM   #11
Rewards Points: 3,238
Originally Posted by Fairview View Post
Top of page 2
The top of page 2 describes a technique for drying compound, not setting compound. You can't do that with setting compound because it sets while wet.
jeffnc is online now   Reply With Quote
How to seal water line on outside to prevent leak into basement goshenplumber General DIY Discussions 14 10-27-2013 01:56 AM
Mysterious Yellow How Water in Tub only heyjoe91 Plumbing 11 10-22-2013 03:23 PM
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Installation and support of water heater expansion tanks. Homerepairguy Plumbing 46 01-28-2013 05:55 AM
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
