2 Drywall Boards Behind Shower Tiles? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-15-2008, 01:49 PM   #1
2 Drywall boards behind shower tiles?
Hi. I'm replacing the shower tiles in my house that was built looooong ago. As I was taking off the wall tiles in the shower, I noticed there were 2 layers of drywall. One acted as the main wall and another on top of that. Both of them are being taken out for replacement but I just wanted to know if I HAD to put that 2nd piece of drywall on top of the other? Was hoping I didn't have to because that would add maybe a couple inches of space all around and would make it look nicer. Thought maybe there was a newer thinner type of material out there to protect the first drywall. Hope the pics comes out good
Also, I'm going to replace the tiles on the shower floor. Is the process the same for taking those out? All I did for the walls was remove some of the grouting on one time and just pulled away.
Confused1 is offline   Reply With Quote
Old 09-15-2008, 02:25 PM   #2
Registered User
Termite's Avatar
There should not be drywall behind shower walls. It is a poor practice that crumby builders employ, and is now illegal by code. Instead of re-installing drywall, you should install 1/2" thick cement backerboard. It comes in 3x5' sheets and is screwed to the wall. Much better substrate for tile. Since tile/grout is nowhere near waterproof, the backerboard needs to be waterproofed with an application of RedGuard, Kerdi, or a similar product before tile is applied.
As for removal of tiles from the floor...Hopefully there's a cement mud bed under the tile, as well as a drain membrane to direct water to the drain. Whether or not you'll be able to remove the tiles without compomising either will be luck of the draw.
Old 09-15-2008, 02:26 PM   #3
Registered User
Termite's Avatar
One layer of 1/2" cement board is the norm, so you don't need two layers.
Had the tiles been properly installed, you'd have never got them to come off. Be sure to use dry mix thinset, not mastic, when you apply the new tiles. Mastic is baaaaad in wet areas.
Old 09-15-2008, 08:28 PM   #4
Thanks for the great info!
Here is where I'm currently at. I don't know what I got myself into but I'm definitely hoping to do this on my own.
http://img169.imageshack.us/my.php?image=img0163fp5.jpg
http://img247.imageshack.us/my.php?image=img0164ei9.jpg
http://img515.imageshack.us/my.php?image=img0165sv4.jpg
In the pic from my first post you see 2 rows of tile still there at the bottom center. In http://img169.imageshack.us/my.php?image=img0163fp5.jpg
there was a cement behind it, almost like a cement wall. It was about 1 1/2" thick and runs all the way down in between the flooring and the wall. I went ahead and took most of it out.
http://img247.imageshack.us/my.php?image=img0164ei9.jpg shows how far up the tiles went. They didn't take it all the way up to the ceiling, which is what I want to do. The red dashes show where I want to cut the drywall for replacement with the cement boards. I'd rather just replace the areas I need rather then that whole side of the bathroom.
As far as the installation of the flooring goes, anything I need to know about that? When I took the tiles off, there was nothing underneath except for the, I'm guessing that's the cement mud bed your talking about.
I think (I hope) taking everything down is the hardest part. Once I get all the material together, it should be smooth sailing.
Old 09-15-2008, 09:13 PM   #5
Registered User
Termite's Avatar
OK. Don't get excited to hang tile just yet. The devil's in the details and the prep work! Hang your backerboard with "rock on" brand or similar backerboard screws. I'd put a screw every 6-8" in every single stud. Once you hang your dura-rock or wonderboard (or similar) cement backerboard on the walls where you'll be tiling, you'll need to mud and tape the seams. The tape is mesh fiberglass tape specifically for backerboard, and the mud is dry mix thinset. This unifies the joints. If you don't do it, you're guaranteed it will crack your grout joints near the seams. It doesn't have to look good, it is purely for function. Use a putty knife to mud the joint with thinset mixed to a peanut butter consistency, bed the tape in the mud, add a bit more mud to cover it up, and smooth it out. It takes 10 minutes or less.
Not knowing exactly what is going on in the floor scares me. If the mud bed appears to be solid go ahead and re-use it. However, I strongly recommend that you use the Kerdi system by Schluter since you don't know what sort of membrane, if any, is under there. Kerdi will also take care of waterproofing the walls. It isn't cheap, but is absolutely the best system there is for tile showers, and it is pretty much foolproof. It will also make the transition from floor to walls watertight. Youtube has plenty of videos on this stuff I'm sure.
Old 09-15-2008, 09:16 PM   #6
Registered User
Termite's Avatar
To answer your question about the floor, it is simply set in thinset mortar. Be sure it pitches toward the drain, which I'm assuming it does.
Don't use the pre-mixed thinset. Buy HIGH QUALITY thinset, not cheapo stuff. It does make a difference.
Old 09-15-2008, 10:56 PM   #7
I wonder if I can just break down the floor mix / mud bed down to the sub floor and just start fresh, new liner and all. Like you said, its a mystery whether or not there is anything under there. I figure if I've went this far, I might as well go the extra steps and make sure its done right. Besides, everything looks kind of rotten and aged. Not sure what would be the most effective way of doing that but I'm guessing chisel out piece by piece.
Also, http://www.youtube.com/watch?v=JNB8b...eature=related gives a really good perspective on the steps of what to do.
And BIG thanks for all your help so far!
Old 09-17-2008, 07:13 PM   #8
Ok I'm about ready to put it all together but one last question. The flooring is cement and not wood. When I apply the material (in this case, roofing paper), I'm assuming I will be using an adhesive of some type instead of stapling. Is there anything you recommend I use as far as the adhesive goes? Or anything to just keep it from moving
Old 09-18-2008, 06:02 PM   #9
Registered User
Termite's Avatar
The flooring? Are we talking about the bathroom floor or the shower pan floor?
If it is the bathroom floor, and the substrate is cement (not cement backerboard...an actual slab), take a look at Ditra. Good way to put tile over concrete.
Old 09-22-2008, 01:56 PM   #10
Ok almost there! Now where the backerboard meets the floor, I read that I leave .25" space there. Is that for the tiling to slide in there? Or am I supposed to fill that gap up?
Old 09-22-2008, 03:49 PM   #11
RippySkippy's Avatar
Originally Posted by thekctermite View Post
There should not be drywall behind shower walls. It is a poor practice that crumby builders employ, and is now illegal by code. Instead of re-installing drywall...the backerboard needs to be waterproofed with an application of RedGuard, Kerdi...
Just for clarification if someone is considering Kerdi, it does go over standard drywall in a shower...NOT cement board. If one uses Kerdi, it should be applied with a high quality, un-modified thin set.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 09-25-2008, 01:29 AM   #12
Where the cement board meets the drywall ceiling, what do I do there? I'm going to tile the wall all the way up to the ceiling but I'm not sure if I just use thinset to fill the gap or what.
Old 09-25-2008, 09:10 PM   #13
Confused1,,, My new handle is confused 2...
did you replace the shower pan? your post 9/17
tar paper? old liners looked like that. and older liners were made of lead.
odds are you will need to cut your tile as you meet the ceiling..
cute tricks are to plan a border below and make two even rows to the top.
If you did not replace the pan while wide open... buy extra floor and wall tile and save or buy more grout...(to go 3 or 4 high at base perimeter) if you bought and installed sanitary base ...buy more ...bull nose ..cap etc.
or risk a patch job in the near future.
Now is or was the time to replace the shower pan.
Big Bob is offline   Reply With Quote
Old 02-01-2010, 05:57 PM   #14
There should not be drywall behind shower walls. It is now illegal by code?
I noticed in the thread that drywall behind showers is illegal by code and I was wondering if anyone would please direct me to where the code states this specific issue. I am having an issue with really shoddy workmanship and they are telling me that the code does not specify that drywall is illegal.
Any help would be greatly apprecited by "thekctermite" or anyone else who might have information on this matter.
Thank you
dgustin is offline   Reply With Quote
Old 02-01-2010, 06:00 PM   #15
Thank you
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Repairing Shower Tiles, Gap between Tub/Drywayll Zulu Plumbing 7 01-22-2008 02:25 PM
Cracking Grout Between Shower Tiles average General DIY Discussions 9 05-08-2007 03:20 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Replacing A Few Tiles On Shower Wall EDENO Remodeling 1 12-11-2006 12:25 PM
