Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Drywall & Plaster
Old 05-24-2011, 09:05 PM   #1
Question
16" vs. 24" o.c. studs
I am finishing the basement and putting up a stud wall in front of the concrete walls. Was planning 2x4's 24" o.c. with 1/2"drywall. The inspector said I needed either 16" o.c. studs or 5/8" drywall. I'm not sure if he was giving friendly advice or telling me what the code required.
Any advice??
Bicoronal is offline   Reply With Quote
Old 05-24-2011, 09:28 PM   #2
firehawkmph's Avatar
1/2" drywall on 24" centers will be pretty flimsy. Add the extra studs and put them 16" oc and do the job right. Cost difference is minimal.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 05-24-2011, 09:30 PM   #3
Framing Contractor
I bet in your basement, you will only use 15 or 20 more studs going 16" oc. I haven't framed a wall 24" oc in at least 20 years.
sixeightten is offline   Reply With Quote
Old 05-24-2011, 10:28 PM   #4
I also recommend 16" O.C. If you do 24" O.C. and 5/8 drywall, you'll be spending more money and lifting heavier drywall.
nateshirk is offline   Reply With Quote
Old 05-24-2011, 10:32 PM   #5
Framing Contractor
And standard door jambs wont work either.
Old 05-26-2011, 12:30 AM   #6
Don't do 24" oc... that's what people who don't know what they are doing do. Go 16" oc and use 1/2" drywall.
Dan
dberladyn is offline   Reply With Quote
Converting 24" on center to 16" on center newbie731 Carpentry 19 02-24-2011 03:22 AM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
5/8" drywall on steel studs 24" OC Charles_cz Drywall & Plaster 11 06-08-2009 09:39 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
