1/4 Inch Drywall Vs Bead Board - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 08-11-2012, 01:11 PM   #1
1/4 inch drywall vs bead board
I have two walls that are half paneling and half drywall. Would it be better for me to replace the paneling with bead board or just put 1/4 inch drywall over the existing drywall and paneling? Thoughts and opinions are appreciated!
THump is offline   Reply With Quote
Old 08-11-2012, 01:54 PM   #2
couldn't you just remove the paneling and patch the wall under it? if i was gonna put 1/4 inch drywall on the wall i would remove the paneling first anyway.
Old 08-11-2012, 03:25 PM   #3
Its a concrete foundation wall under the paneling. Wood frame starts under the existing drywall. Sorry, that would have been an important piece of info to give.
WAINSCOTTING With BEAD BOARD Nathan Carpentry 29 02-24-2013 04:42 PM
Hardibacker Cement Board Thickness Issue With Drywall JasonCA Remodeling 4 02-24-2013 02:00 AM
Is it possible to do an entire home interior in cement board & avoid flimsy drywall? jws3 Drywall & Plaster 30 09-13-2009 02:01 PM
Shower has drywall (not green) can I install Cement board Right over it? jwhiteuwc Drywall & Plaster 14 02-03-2009 03:20 PM
drywall corner bead drewhart Drywall & Plaster 2 10-22-2008 10:28 AM
