1/4" Flex Rock - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 04-25-2013, 02:41 PM   #1
Rewards Points: 1,092
1/4" flex rock
I am planning rounded corners for my house hallways. My plan is to bend 1/4" Flex Rock on an 8" radius. I have never used the flexible 1/4" sheetrock before. Will it bend to an 8" radius? If not, what is the tightest radius I can bend it to? Does it need to be wetted and bent slowly, say over a two day period, then allowed to dry in a jig? I will install 2 layers of it, and the ends where it meets the 5/8" 'rock on the walls will be "butt boarded" in some fashion. Thanks. john
Old 04-25-2013, 05:22 PM   #2
Rewards Points: 5,974
You should not need to wet flex board. But to be honest an 8" radius seems awful tight. I would check the companies web site to see if that is doable. Or maybe someone on here will know.
Old 04-25-2013, 06:58 PM   #3
Rewards Points: 512
i did a job last year with some really tight outside corner curves at the bottom of a stair case for getting furniture down the stairs and around the corner easier. they were around a 10-12". i put studs in every 2-3inches. and then i layed the drywall on the floor face down and dumped a bucket of water on it and let it sit for 20-30min. i then took the sheet and i started at one side and screwed my way down each stud screwing every 4-6" on each stud. The trick to wetting it is getting it wet enough to be able to flex to what you need but not to mushy that the screws cant hold the paper. 8" might be a little to tight.
if anyone has a better way i'd like to hear in case i ever run into this situation again.
princelake is offline   Reply With Quote
Old 04-25-2013, 08:15 PM   #4
www.inspectorzo.com
Send a message via Skype™ to InspectorZo
Talking
Agree!
My suggestion is 12" minimum radius to be safe.
btw, if the screws (don't use nails) screw through/crumble the outer paper, it's too wet. You need to maintain that outside paper in tact to avoid cosmetic problems on the radius later.
Good Luck!
InspectorZo
InspectorZo is offline   Reply With Quote
Old 04-25-2013, 09:20 PM   #5
Registered User
Rewards Points: 5,516
http://www.google.com/url?sa=t&rct=j...,d.cGE&cad=rja
Gary
The Following 3 Users Say Thank You to Gary in WA For This Useful Post:
InspectorZo (04-25-2013), princelake (04-26-2013), ToolSeeker (04-26-2013)
Flex Duct? kimberland30 HVAC 12 04-22-2013 11:45 PM
Getting rid of river rock Shadoglare Landscaping & Lawn Care 9 06-14-2010 10:51 AM
Sheet rock (1/4") in trailer house sagging chrissygarden Building & Construction 4 08-19-2009 10:53 PM
Building a deck on solid rock time2scream Building & Construction 3 03-05-2009 07:45 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
