1/4" Drywall Ran Parallel - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-12-2011, 10:30 PM   #1
1/4" drywall ran parallel
Installed over existing 1/2" drywall ceiling. Ran parallel to oppose existing seems. Attached w/ 1 5/8" screws. Scabbed sides of attic rafters to ensure sides are screwed.
Question: I did not glue it. Do you think I will have problems with sagging?
Thanks for your 2 cents!
rraabb11 is offline   Reply With Quote
Old 05-12-2011, 10:54 PM   #2
Did you screw the field? Three screws?
I don't know... never done that before. Not on a ceiling.
dberladyn is offline   Reply With Quote
Old 05-12-2011, 10:57 PM   #3
Screwed the field and sides.
Old 05-12-2011, 10:58 PM   #4
Too Short? Cut it Again!
Assuming the 1/2 inch is screwed in properly I don't see why you would have a problem. Did you mean to say perpindicular or parallel as far as avoiding seams?
Old 05-12-2011, 11:03 PM   #5
The original 1/2" was hung perpindicular. I ran mine opposite. I figured if it settled it wouldn't crack the new seams. Then again the house is 35 yrs old so i shouldnt have worried about that. Think i should tear it all down and do w all new 1-2"? I really don't want too plus replace insulation. Just nervous because of it's direction but also no glue. Alot of screws should help I hope.
Old 05-12-2011, 11:08 PM   #6
35 year old house... your trusses are most likely on 16" centers. But then you ran parallel to them...
I don't know, I wouldn't have used 1/4" on a ceiling. I would have just added another layer of half inch if it was me and I would have ran perpendicular to the trusses starting out with a 24" strip to ensure I don't land on the previous joint.
The house won't settle any further, what you are concerned with is that quarter inch losing it's fight with gravity. You'll probably be fine, but use 1/2" next time.
Old 05-12-2011, 11:12 PM   #7
Haha definately no next time!
Correct 16" on center. 2x6. Ran 1/4" for can light depth too. Its the gravity issue that freaks me out. Parents house. Real embarrassed if i have to do it again.
Old 05-13-2011, 08:16 AM   #8
Sorry to bump this, but I have to make a decision today!
Old 05-13-2011, 09:12 AM   #9
Next Time...New Build
Rewards Points: 150
If you are that worried about it, why not just zip a few more screws in the fields? As long as your screws were hitting the trusses and not just into the old drywall then I would expect you to be fine.
RickyBobby is offline   Reply With Quote
Basement drywall ceiling and walls questions enero Drywall & Plaster 6 06-05-2010 03:13 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
drywall for vaulted ceiling mdudu Roofing/Siding 5 03-02-2010 12:24 AM
Drywall over plaster? Rob1980 Drywall & Plaster 10 04-11-2009 05:05 PM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
