-   -   1/4" drywall ran parallel (http://www.diychatroom.com/f101/1-4-drywall-ran-parallel-104325/)
rraabb11 05-12-2011 10:30 PM
Installed over existing 1/2" drywall ceiling. Ran parallel to oppose existing seems. Attached w/ 1 5/8" screws. Scabbed sides of attic rafters to ensure sides are screwed.
Question: I did not glue it. Do you think I will have problems with sagging?
Thanks for your 2 cents!
dberladyn 05-12-2011 10:54 PM
Did you screw the field? Three screws?
I don't know... never done that before. Not on a ceiling.
rraabb11 05-12-2011 10:57 PM
Screwed the field and sides.
user1007 05-12-2011 10:58 PM
Assuming the 1/2 inch is screwed in properly I don't see why you would have a problem. Did you mean to say perpindicular or parallel as far as avoiding seams?
rraabb11 05-12-2011 11:03 PM
The original 1/2" was hung perpindicular. I ran mine opposite. I figured if it settled it wouldn't crack the new seams. Then again the house is 35 yrs old so i shouldnt have worried about that. Think i should tear it all down and do w all new 1-2"? I really don't want too plus replace insulation. Just nervous because of it's direction but also no glue. Alot of screws should help I hope.
dberladyn 05-12-2011 11:08 PM
35 year old house... your trusses are most likely on 16" centers. But then you ran parallel to them...
I don't know, I wouldn't have used 1/4" on a ceiling. I would have just added another layer of half inch if it was me and I would have ran perpendicular to the trusses starting out with a 24" strip to ensure I don't land on the previous joint.
The house won't settle any further, what you are concerned with is that quarter inch losing it's fight with gravity. You'll probably be fine, but use 1/2" next time.
rraabb11 05-12-2011 11:12 PM
Haha definately no next time!
Correct 16" on center. 2x6. Ran 1/4" for can light depth too. Its the gravity issue that freaks me out. Parents house. Real embarrassed if i have to do it again.
rraabb11 05-13-2011 08:16 AM
Sorry to bump this, but I have to make a decision today!
RickyBobby 05-13-2011 09:12 AM
If you are that worried about it, why not just zip a few more screws in the fields? As long as your screws were hitting the trusses and not just into the old drywall then I would expect you to be fine.
