1/4 - 3/8" Gap Inbetween Ceiling And Wall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 09-20-2010, 10:15 AM   #1
1/4 - 3/8" gap inbetween ceiling and wall
I am redoing some drywall and in some places where the ceiling meets the wall there is a 1/4 to 3/8 gap between the two boards, because of the ceiling not being flat.. How do you fill that? Do you just fill it on the tape coat with mud or do you fill it in first with something else?
Thanks,
Scott
spetrola is offline   Reply With Quote
Old 09-20-2010, 10:40 AM   #2
Old School
Willie T's Avatar
The first thing you do is get up there and remove all those ceiling fasteners you put in within about 16" of the walls. Hopefully, that will let the ceiling lids droop down to the top edges of the wall boards. If not, you need to re-adjust (install again) the upper wall boards to produce a nice, straight line where they intersect with the ceiling, shoved up, holding the ceiling edge up.
It's probably too late now, but there are clips (shown below) made to hold the tops of the wall sheets and the ceiling sheets together. But they need to be installed before you hang the first wall boards.
Also modern advancements have made it totally unnecessary to fight with the big, fat and wide end joints (where the board is not tapered). But you are also likely well beyond doing anything about that now too.
Willie T
Old 09-20-2010, 04:44 PM   #3
Drywall contractor
Rewards Points: 1,070
Pre-fill with a setting type compound.
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 09-20-2010, 08:10 PM   #4
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,216
As an option you could install crown molding.
Coastal South Carolina
Old 09-20-2010, 08:34 PM   #5
Ole Wood Worker
BigJim's Avatar
Rewards Points: 400
Is there not a sheet rock nailer on top of the top plates on the wall where the gap is? If it is not there should be. You may be able to move the insulation away from the plate and install a 2X6 or 2X8 on top of that wall or 2 2X4s nailed side by side for a sheet rock nailer.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 09-21-2010, 07:42 AM   #6
Thanks, I went and got some Durobond and filled the gaps and walla it's ready to tape and mud.
Scott
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
Where new wall and "popcorn" ceiling meet klein Drywall & Plaster 2 02-04-2010 12:20 PM
Removing spine wall beko Building & Construction 12 02-02-2010 01:15 AM
Wall to ceiling fw2007 Electrical 4 03-31-2008 06:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
