1/2" Vs 1/4" Drywall - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 03:46 PM   #1
Rewards Points: 248
1/2" vs 1/4" drywall
The question has probably been asked a million times but the search feature on this forum wasn't too helpful.
What are the pros/cons of using 1/2" drywall vs 1/4" drywall?
I have found drywall screws don't dig into 1/4" as well. 1/2" drywall is heavier. Any other factors I should consider when making a decision?
jackwashere is offline   Reply With Quote
Old 05-31-2012, 03:55 PM   #2
retired union carpenter
Send a message via Yahoo to coupe
#1= the fire stop value,#2= your standard door/window frames/jambs are made for 1/2"
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
Old 05-31-2012, 03:59 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
1/4" drywall is too thin and flimsy to be used as a stand alone wall or ceiling board. If somebody just leans on the wall they will punch through it. Use 1/2".
Old 05-31-2012, 04:13 PM   #4
Rewards Points: 268
I have only used 1/4" as a laminate when I had to cover an old wall. Last time I did this was when I had removed paneling and it would have been too time consuming to scrape and skim the wall.
packer_rich is offline   Reply With Quote
The Following User Says Thank You to packer_rich For This Useful Post:
oh'mike (05-31-2012)
Old 05-31-2012, 04:23 PM   #5
DIY staff
Rewards Points: 7,174
1/4 inch is only used for skinning over existing drywall--or for bending around curved walls (double layer of 1/4 inch)
It's more expensive than 1/2 inch and requires more screws ,when used as a skin,so 1/2" is often used for skinning a bad ceiling --
Old 05-31-2012, 10:53 PM   #6
Registered User
Rewards Points: 5,492
As you mentioned "heavier"--- use 1/2" LightRoc (1.2-1.4#)- it's about the same weight as 1/4" regular drywall (1.2#) yet it will stand alone and span perpendicular ceiling framing with a texture at 24"o.c.: https://docs.google.com/viewer?a=v&q...U1o3kfoOlKl-7Q
http://www.americangypsum.com/data/p...alsheet541.pdf
Gary
Old 06-01-2012, 03:55 PM   #7
Drywall contractor
Rewards Points: 1,070
1/4" is more expensive. Only comes in 8' lengths (unless you buy at a drywall supply), so more butt joints. Too flimsy (will sag on ceilings) unless used to go over an existing wall/ceiling. Just to name a few reasons......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-01-2012, 04:19 PM   #8
Rewards Points: 256
i dont see where the weight difference makes enough of a issue . i mean its not that heavy neither is 5/8ths for that matter. never seen anywhere where the weight of drywall was an issue .
oldrivers is offline   Reply With Quote
Drywall question. DerWookie Drywall & Plaster 11 11-08-2011 07:08 AM
1/4" Drywall requires 1/4" backerboard? aweekendwarrior Kitchen & Bath Remodeling 4 10-06-2011 10:08 PM
Do I Need To Strap Exterior Walls (Interior Side) Before Drywall? Dreams Drywall & Plaster 4 09-26-2011 04:37 PM
Matching new drywall to old textured drywall pennshaq Drywall & Plaster 1 05-23-2010 09:30 AM
Good ways to run pegboard up to drywall? upthemaiden Drywall & Plaster 1 03-09-2009 01:12 PM
