1/2" Joist Sag Over 5' Noticeable Under New Drywall? - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-13-2014, 10:39 AM   #1
Rewards Points: 26
1/2" joist sag over 5' noticeable under new drywall?
I ripped out a drop ceiling in a recently purchased home and have found the ceiling/2nd floor joists have a 0.5" sag in them over a 5' run. This not structural as per the ST eng. My question is whether or not this would be noticeable once the dry wall has gone back up. This is in a kitchen and will now be an 8' ceiling with can lights.
Thanks.
dzl13 is offline   Reply With Quote
Old 02-13-2014, 03:10 PM   #2
Civil Engineer
Rewards Points: 4,686
As long as your structural engineer says it is OK, the only reason to "fix" it is if you want a flat ceiling. This can easily be done by sanding or planing the joist flat. 1/2 inch in 60 inches is l/D = 120, which may be noticeable.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
joecaption (02-13-2014)
Old 02-13-2014, 09:29 PM   #3
Professional
TotalHomeworx's Avatar
It will be more noticeable in larger rooms but not in a small one. May be easier to sister up the joists with straight wood and build it down until it's flat.
www.totalhomeworx.ca
TotalHomeworx is offline   Reply With Quote
Old 02-15-2014, 07:49 AM   #4
Rewards Points: 236
if i had to do that, and wanted to maintain the same ceiling height. i would sister new boards. the use a resip saw to cut off what was sagging below them.
Fix'n it is offline   Reply With Quote
Old 02-15-2014, 08:39 AM   #5
Davejss's Avatar
Rewards Points: 740
Is there strapping, or were you planning to attach the drywall right to the joists? Normally there would be strapping running perpendicular to the joists which you could shim to feather out that sag.
Davejss is offline   Reply With Quote
Old 02-15-2014, 10:12 AM   #6
Rewards Points: 153
Whether it will be noticeable or not depends on where it is in relation to cabinets and trim, lighting location, etc.
If you have a sag, I wouldn't be planing those joists. Shims and strapping down will flatten the whole ceiling, if you want a totally flat / level ceiling.
eandjsdad is offline   Reply With Quote
1/2" vs 1/4" drywall jackwashere Drywall & Plaster 7 06-01-2012 04:19 PM
The CELLAR gbwillner Project Showcase 112 02-17-2012 10:00 PM
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
one rotted deck joist to replace, need advice dougq Building & Construction 10 07-07-2009 02:18 PM
