1/2 Inch Drywall Over Ridged Foam - Drywall & Plaster - DIY Chatroom Home Improvement Forum
Old 02-17-2012, 11:12 AM   #1
1/2 inch drywall over ridged foam
Trying to add another inch of insulation to my detached shop loft ceiling and cover the rafters. Plan is to nail directly over rafters. Can I then nail drywall directly over foam or must I use some sort of furring strips?
Thanks.
bullhome is offline   Reply With Quote
Old 02-17-2012, 03:53 PM   #2
Registered User
Rewards Points: 5,466
Is the cathedral ceiling vented?
http://www.buildingscience.com/docum...n-roof-venting
Gary
Old 02-17-2012, 04:06 PM   #3
Rewards Points: 13,446
Why not just add insulation on top of the ceiling joist?
You need 5/8 sheetrock for a ceiling not 1/2".
Use screws not nails.
Old 02-18-2012, 01:34 AM   #4
Anyone ever done this? Fastened sheetrock through ridged foam right to the rafters?
Old 02-18-2012, 01:42 AM   #5
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Sorry. I must agree, just put more insulation in
titanoman is offline   Reply With Quote
Old 02-18-2012, 02:31 AM   #6
Put more insulation in where?
Old 02-18-2012, 02:42 AM   #7
Disabled wood vet
titanoman's Avatar
In the rafters, regular batted fiberglass, or in the joists like Joecaption says. The rigid insulation hasn't nearly the needed r-value.
And the sheetrock will never be completely flat nailed over "semi" rigid insulation, even with fir strips.
It'll be wavy.
Old 02-18-2012, 02:48 AM   #8
There are no joists. Cathedral. Have bats between 2x6 already. Want therml break. 2 more inches ridged gives me another r-10.
Wavey. Interesting.
Old 02-18-2012, 02:53 AM   #9
Disabled wood vet
titanoman's Avatar
I'm just thinking it could be wavy, unless you're real good and can dish sheetrock nails or screws without the rigid insulation crushing a little, especially near the edges, and be consistent.
But maybe not.
I'm just hypotherizing and thinking out loud.
Old 02-18-2012, 03:06 AM   #10
I read somewhere that if I pre-drill, the likelihood of the foam crushing is less, but I haven't tested this. Want to use the Owens Corning extruded polystyrene (XPS) rigid foam. Maybe an inch would be better it's still an extra r-5.
Thanks for the replies.
Old 02-18-2012, 03:17 AM   #11
Disabled wood vet
titanoman's Avatar
I can see that working.
Old 02-18-2012, 07:01 AM   #12
Is there insulation up there now?
Do you have foam baffles in the bays, soffit vents and and a ridge vent on the roof?
Is this a shingled roof?
Old 02-18-2012, 11:54 AM   #13
yes
yes
yes
Old 02-18-2012, 11:59 AM   #14
Rewards Points: 528
1/2 inch drywall is fine for a ceiling.
It can go over the foam with no problems except maybe a little extra finishing.
framer52 is offline   Reply With Quote
Old 02-18-2012, 10:29 PM   #15
Rewards Points: 2,210
1/2" ceiling board is stiffer, we use it all the time.
mae-ling is offline   Reply With Quote
Drywall Damage After Wallpaper Removal katega Drywall & Plaster 1 01-28-2012 10:11 PM
Foam board and electrical boxes Master Brian Electrical 5 11-21-2010 07:03 PM
rigid foam insulation on interior itin1200 Building & Construction 24 10-17-2010 07:22 PM
240V 2 pole 1/2 inch GE breakers? Isaac-1 Electrical 12 02-09-2010 11:21 AM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 09:42 PM
